<qqi@world.std.com>). Unfortunately after merging these,
the pc386 will not boot using grub for for. It still does not
work using netboot for me. Here is his summary of changes:
rtems/c/src/lib/libbsp/i386/pc386/Makefile.in
Added support for new sub-directory
rtems/c/src/lib/libbsp/i386/pc386/bsp_specs
Made possible to build COFF image
rtems/c/src/lib/libbsp/i386/pc386/console/console.c
Added support for serial consoles, selectable by patching
binary image, added __assert(), use _IBMPC_inch_sleep()
instaed of _IMBPC_inch()
rtems/c/src/lib/libbsp/i386/pc386/console/inch.c
Added _IMBPC_inch_sleep()
rtems/c/src/lib/libbsp/i386/pc386/console/outch.c
Oops - just formatting
rtems/c/src/lib/libbsp/i386/pc386/include/Makefile.in
Added support for new files
rtems/c/src/lib/libbsp/i386/pc386/include/bsp.h
Added support for new features
rtems/c/src/lib/libbsp/i386/pc386/include/pc386uart.h
New file: definitions for serial ports
rtems/c/src/lib/libbsp/i386/pc386/include/pcibios.h
New file: definitions for PCI BIOS
rtems/c/src/lib/libbsp/i386/pc386/pc386dev/Makefile.in
New file: makefile in new directory
rtems/c/src/lib/libbsp/i386/pc386/pc386dev/i386-stub-glue.c
New file: i386-stub interface
rtems/c/src/lib/libbsp/i386/pc386/pc386dev/i386-stub.c
New file: i386-stub itself
rtems/c/src/lib/libbsp/i386/pc386/pc386dev/pc386uart.c
New file: serial ports
rtems/c/src/lib/libbsp/i386/pc386/pc386dev/pcibios.c
New file: PCI BIOS support
rtems/c/src/lib/libbsp/i386/pc386/start/start.s
Commented out DEBUG_EARLY stuff, everything is working fine
rtems/c/src/lib/libbsp/i386/pc386/start/start16.s
Cleaned up
rtems/c/src/lib/libbsp/i386/pc386/startup/bspstart.c
Added call to console_resereve_resources
rtems/c/src/lib/libbsp/i386/pc386/startup/exit.c
rtems/c/src/lib/libbsp/i386/pc386/startup/ldsegs.s
Fixed typo in comments
rtems/c/src/lib/libbsp/i386/pc386/tools/Makefile.in
Changed to reflect cnages in code
rtems/c/src/lib/libbsp/i386/pc386/tools/bin2boot.c
Trivialized, problem - I do not know how to make patch
remove obsolete files - there are a lot of them there
rtems/c/src/lib/libbsp/i386/pc386/tools/binpatch.c
New file: utility to do binary patches
rtems/c/src/lib/libbsp/i386/pc386/wrapup/Makefile.in
Added support for new directory
rtems/make/custom/pc386.cfg
Add COFF image building
all the targets:
breaking CXX support.
handling.
after minor changes.)
insecure about.
external packages.
may be broken).
disturb now.
--enable-* flags).
--enable-gcc28 are given.
mvme162.cfg-bug.
versions of these utilities with C implementations.
subdirectory Makefiles.
used.
individual Makefile.
problem (reported by Eric)
enclose.
<pmcnr@camoes.rnl.ist.utl.pt> and Jose Rufino <ruf@asterix.ist.utl.pt>
of NavIST (http://pandora.ist.utl.pt/).
