* console/inch.c, console/keyboard.c, console/pc_keyb.c,
console/vt.c, include/bsp.h: Correct incorrect interrupt level
handling in new keyboard management code. Correct
BSP_poll_char initialization routine.
* start/start.S, startup/bspstart.c: Correct when the video is
initialized.
* timer/timer.c (Calibrate_1ms_loop): Address problem where this
did not work correctly on all PC speeds. The new calibrate routine
has been tested on Pentium 166, pentium II 200, pentium III
300 Mhz and does work as expected.
Emmanuel Raguet <raguet@crf.canon.fr> to eliminate a problem
during the boot process on the pc386 BSP. On fast PC's the
calibration routine would hand.
moves pieces of the pc386 bsp up to a shared level for all i386 BSPs
and modifies the i386ex BSP to use those shared pieces. Serial remote
debugging is included for both targets. Erik's notes:
There are several workarounds in it:
1) #define NEXT_GAS is hardcoded in pc386/start/start.s
2) #define NEXT_GAS is hardcoded in i386ex/start/start.s
3) #define NEW_GAS is hardcoded in pc386/start16.s
4) #undef __assert and redeclare _assert hardcoded in console.c for
both pc386 and i386ex due to my egcs1.1b ~ newlib problem. Should have
modified t-rtems.cfg ( no time )
I've tested pc386 with both video and serial consoles and GDB remote.
All work fine, except that GDB acts weird. ( re: other posting)
I hope this will work for you. It took quite some time to locate the
autoconf error. The remainder was just grunt work.
Unfortunately, I think I've unwound the removal of the IBMPCInitVideo
stuff. Sorry. I REALLY can't spend more time... I've been at this
conversion to 4.0 locally and updating the release since Sept. 8th, and
have yet to compile my network driver.... This is as much as I can do
right now.
I look forward to the next patch to really test i368ex. I did make sure
that the sample tests worked for pc386.
After some good comments from Eric Norum [thanks, Eric !],
I have added some modifications to my previous driver patch :
- wait for transmitter ready before sending a packet,
- new delay management in case of ring-overwritting.
It fixes netboot build problem, KA9Q configuration
for pc386, some compiler wardning, it also removed some stuff
ifdef'ed with '#if 0'.
inline with the new IRQ structure.
of theses targets...
enclose.
<pmcnr@camoes.rnl.ist.utl.pt> and Jose Rufino <ruf@asterix.ist.utl.pt>
of NavIST (http://pandora.ist.utl.pt/).
