* 3c509/3c509.c: Add <sys/errno.h>.
* startup/linkcmds: Add .jcr section.
* clock/ckinit.c, clock/rtc.c, console/console.c, console/inch.c,
console/outch.c, ide/ide.c, include/bsp.h, include/crt.h,
ne2000/ne2000.c, start/start.S, startup/bspstart.c, startup/exit.c,
startup/ldsegs.S, startup/linkcmds, timer/timer.c, timer/timerisr.S:
URL for license changed.
* startup/linkcmds: Add FreeBSD SYSCTL() sections for networking.
* startup/linkcmds: In support of gcc 3.1, added one of more
of the sections .jcr, .rodata*, .data.*, .gnu.linkonce.s2.*,
.gnu.linkonce.sb2.*, and .gnu.linkonce.s.*. Spacing corrections
and direction of segments to memory regions may also have been
addressed. This was a sweep across all BSPs.
* startup/linkcmds: Added lines so DWARF debug information
would be available. Otherwise gdb complains that the offsets
for the debug info are incorrect and doesn't load the files.
proper Multiboot signature to pc386 BSP. This enables Grub to
recognize the image.
exceptions work on the pc386 BSP with i386-elf. This patch also
included changes to the i386-rtemself egcs configuration.
I noticed that in the 4.0.0-beta4a tar file, the file
c/src/lib/libbsp/i386/pc386/startup/linkcmds
was changed so that it no longer handles the .gnu.linkonce.r*
sections. The appended patch was applied to the file. I'm not sure
why. I think this patch should probably be backed out, although it's
not critical for the release.
moves pieces of the pc386 bsp up to a shared level for all i386 BSPs
and modifies the i386ex BSP to use those shared pieces. Serial remote
debugging is included for both targets. Erik's notes:
There are several workarounds in it:
1) #define NEXT_GAS is hardcoded in pc386/start/start.s
2) #define NEXT_GAS is hardcoded in i386ex/start/start.s
3) #define NEW_GAS is hardcoded in pc386/start16.s
4) #undef __assert and redeclare _assert hardcoded in console.c for
both pc386 and i386ex due to my egcs1.1b ~ newlib problem. Should have
modified t-rtems.cfg ( no time )
I've tested pc386 with both video and serial consoles and GDB remote.
All work fine, except that GDB acts weird. ( re: other posting)
I hope this will work for you. It took quite some time to locate the
autoconf error. The remainder was just grunt work.
Unfortunately, I think I've unwound the removal of the IBMPCInitVideo
stuff. Sorry. I REALLY can't spend more time... I've been at this
conversion to 4.0 locally and updating the release since Sept. 8th, and
have yet to compile my network driver.... This is as much as I can do
right now.
I look forward to the next patch to really test i368ex. I did make sure
that the sample tests worked for pc386.
The pc386 linker scripts omits .gnu.linkonce.r* sections. It's not a
big deal, but they should be treated like .rodata sections. ELF
versions of g++ generate them for static constants defined in template
classes, such as string::npos.
enclose.
<pmcnr@camoes.rnl.ist.utl.pt> and Jose Rufino <ruf@asterix.ist.utl.pt>
of NavIST (http://pandora.ist.utl.pt/).
