line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
This header is used also by the motorola_powerpc BSP.
Update #3254.
Intel has obsoleted this hardware and the BSP was never completed.
closes #3086.
Update #2468.
Move the gdb stub from the i386 UART code to use the libchip drivers.
Use any ports discovered during the probes.
Add gdb control to the boot command line.
Change the device naming to the full device path, not a partial path.
For example /dev/com1.
suppress GCC 6 warning.
closes #2634
Start to migrate private symbols to bsp/bspimpl.h.
This patch adds the "--printk=" boot command line argument to specify
the printk() device. It also enhances the "--console=" boot command
line argument to match any device configured in the console device
table. The arguments are parsed as early as possible so they take
effect early. Currently, this is immediately after PCI initialization.
configuration space
This patch fundamentally results from enhancements to the pc386 BSP
to support systems which do **NOT** have the legacy PCI BIOS. The
patch adds support for detecting when legacy PCI BIOS is not
present and then using IO space to access to PCI Configuration Space.
This resulted in dynamically selected between two implementations
of PCI and refactoring out the shared methods.
This patch adds shared implementations of pci_bus_count() and
pci_find_device(). Subsequent patches will remove implementations
of these methods in other BSPs where possible.
Fixes #2515.
This avoids potential dead code in _Thread_Handler(). It gets rid of
the dangerous function pointer casts.
Update #2514.
Call bsp_work_area_initialize() before bsp_start(). This allows
bsp_start() to use malloc() etc. which is beneficial for systems with a
plug-and-play hardware enumeration.
Update #2408.
do
echo $b
# echo $g
-i $b
done
The current support for the Edison supports a single polled
UART for input and output plus a simulated clock tick. The
activities forward for supporting the Edison have been posted
on the RTEMS mailing lists and at:
http://rtemsramblings.blogspot.com/2014/12/intel-edison-and-rtems-road-forward.html
This allows the IDE support to be completely disabled. It is needed to
prevent hangs on some hardware. In particular, the Intel Edison where
it is not present.
structs, break >80 chars lines, removed newlines at EOFs
fb_vesa_rm.c: removed inline from functions declared in fb_vesa.h
removed unnecessary printks in the end of patch
edid.h, vbe3.h: switched from custom *PACKED_ATTRIBUTE at the structs to the
RTEMS_COMPILER_PACKED_ATTRIBUTE for easier maintainability
of doxygen
Display Identification Data
crt.h defines such lovely constants as "RED" and "GREEN" which
have a nasty habit of conflicting with non-BSP code. There is
no reason to include this private .h from bsp.h and pollute the
namespace for applications.
Conflicts:
This was broken by conversion of console driver to libchip style.
PR 1925
* Makefile.am, preinstall.am, console/serial_mouse_config.c,
include/bsp.h, start/start.S: Converted 1386 console to the libchip
style console
* console/conscfg.c, console/console_control.c,
console/printk_support.c, console/vgacons.c, console/vgacons.h: New
files.
* include/bsp.h, include/tm27.h:
* clock/rtc.c, console/console.c, console/inch.c, console/outch.c,
include/bsp.h, include/crt.h, ne2000/ne2000.c, startup/bspcmdline.c,
startup/bspstart.c, startup/ldsegs.S, timer/timer.c,
timer/timerisr.S: Fix typo where license said found in found in.
* include/bsp.h: Add BSP_HAS_FRAME_BUFFER.
* include/bsp.h, startup/bspgetworkarea.c: Rework bsp_size_memory() to
ensure that multiboot information regarding memory size is used as
the primary source. This was broken in the move to supporting a
unified workspace. It worked this way in 4.9 so this was a
regression.
