* | Added AC_SUBST(RTEMS_BSP) so the makefiles properly honor the | Joel Sherrill | 2000-01-31 | 1 | -0/+1 |
| | | | | BSP alias on the tools. | ||||
* | Patch rtems-rc-20000104-15.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-01-12 | 1 | -0/+4 |
| | | | | | | | | | | that fixes the following problems: 1. Removing bogus ';' in some configure.in (cosmetical fix) 2. Moves GAS_CODE16 checks to libbsp/i386/*/configure.in (essential fix) #2 was responsible for the gcc/binutils-2.9.5 choking while building for the pc386. | ||||
* | Patch rtems-rc-20000104-11.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-01-10 | 1 | -0/+40 |
that converts the i386 directory to automake. NOTE: Ralf is unable to build any i386 BSPs. This was true before and after this patch and appears (to Joel) to be a tool issue unrelated since others can build i386 BSPs. |
