Close #3250.
Close #4081.
Update #3818.
Update #3408.
Close #3410.
system. Since all content of
makes no sense to keep it.
Update #3285.
Update #3387.
upgrade to that version.
Close #3387.
Update #3285.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
Updates #3250.
BSP_PRESS_KEY_FOR_RESET=0
BSP_RESET_BOARD_AT_EXIT=1
BSP_PRINT_EXCEPTION_CONTEXT=1
Intel has obsoleted this hardware and the BSP was never completed.
closes #3086.
Move the gdb stub from the i386 UART code to use the libchip drivers.
Use any ports discovered during the probes.
Add gdb control to the boot command line.
Change the device naming to the full device path, not a partial path.
For example /dev/com1.
basic VGA driver can be enabled during configure phase by exporting variable
USE_VGA=1 so that it is available in configure environment
cirrus driver is enabled the same way by exporting variable
USE_CIRRUS_GD5446=1
The current support for the Edison supports a single polled
UART for input and output plus a simulated clock tick. The
activities forward for supporting the Edison have been posted
on the RTEMS mailing lists and at:
http://rtemsramblings.blogspot.com/2014/12/intel-edison-and-rtems-road-forward.html
This allows the support for the legacy COM1-COM4 serial ports
to be completely disabled. It is needed to prevent hangs on some
hardware. In particular, the Intel Edison where it is not present.
This allows the IDE support to be completely disabled. It is needed to
prevent hangs on some hardware. In particular, the Intel Edison where
it is not present.
This allows the VGA and keyboard console to be completely disabled.
It is useful on PCs without displays and prevents a very slow boot
time on the Intel Edison.
The user has to explicitly enable this driver, choosing
it over the existing (and lame) CGA frame buffer driver
using USE_CIRRUS_GD5446=1 on the configure command line.
* configure.ac: Formatting. Remove duplication BSP_HAS_SMP.
PR 1802
* Makefile.am, configure.ac, preinstall.am, clock/ckinit.c,
start/start16.S, startup/bspstart.c, startup/ldsegs.S: Add SMP
support for i386.
PR 1729/cpukit
* Makefile.am, configure.ac: Add next step in SMP support. This adds an
allocated array of the Per_CPU structures to support multiple cpus vs
a single instance of the structure which is still used if SMP support
is disabled. Configuration support is also added to explicitly enable
or disable SMP. But SMP can only be enabled for the CPUs which will
support it initially -- SPARC and i386. With the stub BSP support, a
BSP can be run as a single core SMP system from an RTEMS data
structure standpoint.
* configure.ac: Move comment to correct location.
* configure.ac: Remove RTEMS_BSP_BOOTCARD_OPTIONS.
* configure.ac: Rename BSP_BOOTCARD_OPTIONS to
RTEMS_BSP_BOOTCARD_OPTIONS. Add RTEMS_BSP_CLEANUP_OPTIONS so all BSPs
have the same options.
* configure.ac, start/start16.S: Remove duplicate configure option and
add support for the configure time variable BSP_VIDEO_80x50.
Michael South <msouth@msouth.org>
PR 1344/bsps
* configure.ac, clock/ckinit.c, timer/timer.c: Add use of TSC for
nanoseconds granularity. i8254 is very slow on some systems. TSC use
is auto-detected by default.
* configure.ac: Make letting boot_card() handle work area allocation
mandatory. Rename RTEMS_BSP_BOOTCARD_HANDLES_RAM_ALLOCATION to
* Makefile.am, configure.ac, console/inch.c, console/keyboard.c,
include/bsp.h: Use standardized bsp_cleanup() which can optionally
print a message, poll for user to press key, and call bsp_reset().
Using this eliminates the various bsp_cleanup() implementations which
had their own implementation and variety of string constants.
* Makefile.am, configure.ac, startup/bspstart.c, startup/linkcmds: Add
bsp_get_work_area() implementation and use more of the BSP
Initialization Framework.
* startup/bspgetworkarea.c: New file.
* configure.ac: Remove spurious line.
* configure.ac, startup/exit.c: Add BSP_PRESS_KEY_FOR_RESET
configuration option. When this is set to one, a clean exit of an
application will result in the BSP resetting the hardware without
waiting for a human to press a key.
* start/start.S, startup/linkcmds: Replace the linkcmds with a
version very closely based upon the default in binutils 2.18 for
this target. This eliminated weird failures with C++ dtors even
in C applications. We had an extra _ on a symbol used in start.S.
* configure.ac: Fix typo.
* configure.ac, console/console.c: Add USE_COM1_AS_CONSOLE BSP option.
This makes it easy to build the pc386 BSP in a configuration that
corresponds to qemu with COM1 redirected to stdio.
* configure.ac: Remove explicit ampolish3 support (now in
RTEMS_BSP_CONFIGURE).
* configure.ac: Add ampolish3 support.
* Makefile.am: Add preinstall.am.
PR 649/bsps
* ide/idecfg.c, configure.ac:
added configuration items for primary/secondary IDE interface
