path: root/c/src/lib/libbsp/i386/pc386/bsp_specs (follow)
* Patch rtems-rc-19990709-6-diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1999-08-061-1/+1
* Patch from Rosimildo DaSilva <rdasilva@connecttel.com> to make C++Joel Sherrill1999-06-151-1/+4
| | | | | exceptions work on the pc386 BSP with i386-elf. This patch also included changes to the i386-rtemself egcs configuration.
* PC386 BSP enhancements from Aleksey Romanov (Quality QuorumJoel Sherrill1998-06-271-1/+1
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | <qqi@world.std.com>). Unfortunately after merging these, the pc386 will not boot using grub for for. It still does not work using netboot for me. Here is his summary of changes: rtems/c/src/lib/libbsp/i386/pc386/Makefile.in Added support for new sub-directory rtems/c/src/lib/libbsp/i386/pc386/bsp_specs Made possible to build COFF image rtems/c/src/lib/libbsp/i386/pc386/console/console.c Added support for serial consoles, selectable by patching binary image, added __assert(), use _IBMPC_inch_sleep() instaed of _IMBPC_inch() rtems/c/src/lib/libbsp/i386/pc386/console/inch.c Added _IMBPC_inch_sleep() rtems/c/src/lib/libbsp/i386/pc386/console/outch.c Oops - just formatting rtems/c/src/lib/libbsp/i386/pc386/include/Makefile.in Added support for new files rtems/c/src/lib/libbsp/i386/pc386/include/bsp.h Added support for new features rtems/c/src/lib/libbsp/i386/pc386/include/pc386uart.h New file: definitions for serial ports rtems/c/src/lib/libbsp/i386/pc386/include/pcibios.h New file: definitions for PCI BIOS rtems/c/src/lib/libbsp/i386/pc386/pc386dev/Makefile.in New file: makefile in new directory rtems/c/src/lib/libbsp/i386/pc386/pc386dev/i386-stub-glue.c New file: i386-stub interface rtems/c/src/lib/libbsp/i386/pc386/pc386dev/i386-stub.c New file: i386-stub itself rtems/c/src/lib/libbsp/i386/pc386/pc386dev/pc386uart.c New file: serial ports rtems/c/src/lib/libbsp/i386/pc386/pc386dev/pcibios.c New file: PCI BIOS support rtems/c/src/lib/libbsp/i386/pc386/start/start.s Commented out DEBUG_EARLY stuff, everything is working fine rtems/c/src/lib/libbsp/i386/pc386/start/start16.s Cleaned up rtems/c/src/lib/libbsp/i386/pc386/startup/bspstart.c Added call to console_resereve_resources rtems/c/src/lib/libbsp/i386/pc386/startup/exit.c Added support for serial console rtems/c/src/lib/libbsp/i386/pc386/startup/ldsegs.s Fixed typo in comments rtems/c/src/lib/libbsp/i386/pc386/tools/Makefile.in Changed to reflect cnages in code rtems/c/src/lib/libbsp/i386/pc386/tools/bin2boot.c Trivialized, problem - I do not know how to make patch remove obsolete files - there are a lot of them there rtems/c/src/lib/libbsp/i386/pc386/tools/binpatch.c New file: utility to do binary patches rtems/c/src/lib/libbsp/i386/pc386/wrapup/Makefile.in Added support for new directory rtems/make/custom/pc386.cfg Add COFF image building
* Update from Pedro Romano <pmcnr@camoes.rnl.ist.utl.pt>.Joel Sherrill1998-04-271-1/+1
* Incorporated Ralf Corsepius' idea for new -q flags to properly supportJoel Sherrill1998-02-111-2/+7
| | | | "gmake debug".
* Moved -qnolinkcmds option so arguments passed on the command line areJoel Sherrill1997-12-201-2/+2
| | | | | | | | | | | | | | | | | | | | | interpreted at the right point per Eric Norum's discovery: The problem with the my previous `fix' for adding linker commands was with the ordering of the options to the linker. For example, to make a larger heap size, the application Makefile would CFLAGS_LD = -Wl,--defsym -Wl,HeapSize=0x40000 The command passed to the linker would be : m68k-rtems-ld .... -T xxx/linkcmds .... --defsym HeapSize=0x40000 ..... This doesn't work because the script in linkcmds inserts a default value for HeapSize if HeapSize is not defined by the time the linker looks at the linkcmds script. The solution seems to be to move the -T linkcmds%s in the bsp_specs file out of the link specfication and into the lib specification -- a little unorthodox, perhaps, but it seems to work!
* Modified bsp_specs per Eric Norum's suggestion to handle -qnolinkcmdsJoel Sherrill1997-12-191-1/+1
| | | | switch which lets the user specify a different linker script.
* Inclusion of PC386 BSP submitted by Pedro Miguel Da Cruz Neto RomanoJoel Sherrill1997-12-011-0/+18
<pmcnr@camoes.rnl.ist.utl.pt> and Jose Rufino <ruf@asterix.ist.utl.pt> of NavIST (http://pandora.ist.utl.pt/).
