Close #3250.
Close #4081.
Update #4267.
start16.S is now only used for SMP configurations to start the
application processors.
This commit removes all unnecessary parts for this job,
i.e. video conssole initalisation, A20 gate activation
and all non-AP related code.
Update #3335
Update #3408.
Close #3410.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #2408.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
This was used by the not supported "make dist".
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
With HAS_SMP set, we have:
libbsp_a_LIBADD += appstart.$(OBJEXT)
When trying to build appstart.o, however, we link start.o with appcpustart.o
through the linkcmds script, which leaves several symbols unresolved, and
without the "-r" (or -i) flag, this throws undefined reference errors.
This change requires us to re-run the ./bootstrap script to regenerate
Makefile.in, and therefore the Makefile for the particular BSP as well.
Complete log of errors available here:
https://gist.github.com/AmaanC/d40bd7393dca1f82965938275845b7f9
Updates #3331
* bsps/shared/cache
Update #3285.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
This header is used also by the motorola_powerpc BSP.
Update #3254.
The name suggests that this is a private implementation header file.
Update #3254.
Update #3254.
EXTRA_DIST += foobar
in fragments.
Update #3254.
Update #3254.
If this has any issues, check that the change in linking the
16-bit startup code in Makefile.am generates the same code.
This was odd code and didn't need the RTEMS linkcmds anyway.
Updates #3520.
maintain.
Update #3254.
Update #3239.
