Intel has obsoleted this hardware and the BSP was never completed.
closes #3086.
Fix the interrupt and stop the spurious interrupt from happening.
The fix moves the EOI to C code and cleans that functionality out
of the asm part of the ISR handler.
The code checks the ISR and IRR registers on the enable.
Only ack the master for a slave IRQ if the slave has no other pending
requests.
Move the gdb stub from the i386 UART code to use the libchip drivers.
Use any ports discovered during the probes.
Add gdb control to the boot command line.
Change the device naming to the full device path, not a partial path.
For example /dev/com1.
Start to migrate private symbols to bsp/bspimpl.h.
closes #2638.
configuration space
This patch fundamentally results from enhancements to the pc386 BSP
to support systems which do **NOT** have the legacy PCI BIOS. The
patch adds support for detecting when legacy PCI BIOS is not
present and then using IO space to access to PCI Configuration Space.
This resulted in dynamically selected between two implementations
of PCI and refactoring out the shared methods.
This patch adds shared implementations of pci_bus_count() and
pci_find_device(). Subsequent patches will remove implementations
of these methods in other BSPs where possible.
This first step eliminates the following as public APIs for the pc386
BSP:
+ pcib_conf_read8
+ pcib_conf_read16
+ pcib_conf_read32
+ pcib_conf_write8
+ pcib_conf_write16
+ pcib_conf_write32
The if_fxp.c driver uses these enough where I provided local macros
to allow the code to be mostly unmodified. On other architectures
these names have been used privately. It will take multiple patches
to completely eliminate these symbols from the RTEMS source tree.
The focus of the first effort is just to eliminate these as a public
pc386 API so support can be added for systems without legacy PCI BIOS.
Update #2408.
Update #2408.
basic VGA driver can be enabled during configure phase by exporting variable
USE_VGA=1 so that it is available in configure environment
cirrus driver is enabled the same way by exporting variable
USE_CIRRUS_GD5446=1
driver is not initialized by default
initialization is possible through multiboot command line option or
through the string variable (see fb_default_mode.h) set in user's module
allowing the driver to evaluate this variable after the two
modules are linked together
The current support for the Edison supports a single polled
UART for input and output plus a simulated clock tick. The
activities forward for supporting the Edison have been posted
on the RTEMS mailing lists and at:
http://rtemsramblings.blogspot.com/2014/12/intel-edison-and-rtems-road-forward.html
This allows the IDE support to be completely disabled. It is needed to
prevent hangs on some hardware. In particular, the Intel Edison where
it is not present.
This allows the VGA and keyboard console to be completely disabled.
It is useful on PCs without displays and prevents a very slow boot
time on the Intel Edison.
The dummy.c was a de-facto default configuration. Rename it to
default-configuration.c. Use unlimited objects and the stack checker.
This makes it easier for new RTEMS users which will likely use this file
if they just work with the usual main() function as the application
entry point. Provide proper arguments for main() using the BSP command
line. Add spare user extensions and drivers.
Do not initialize the network by default. Delete bspinit.c.
Display Identification Data
The user has to explicitly enable this driver, choosing
it over the existing (and lame) CGA frame buffer driver
using USE_CIRRUS_GD5446=1 on the configure command line.
This was broken by conversion of console driver to libchip style.
PR 1925
* Makefile.am, preinstall.am, console/serial_mouse_config.c,
include/bsp.h, start/start.S: Converted 1386 console to the libchip
style console
* console/conscfg.c, console/console_control.c,
console/printk_support.c, console/vgacons.c, console/vgacons.h: New
files.
PR 1802
* Makefile.am, configure.ac, preinstall.am, clock/ckinit.c,
start/start16.S, startup/bspstart.c, startup/ldsegs.S: Add SMP
support for i386.
* Makefile.am: Fix broken path to clockdrv_shell.h.
PR 1792/bsps
* src/lib/libbsp/i386/pc386/Makefile.am,
src/lib/libbsp/sparc/erc32/Makefile.am,
src/lib/libbsp/sparc/leon2/Makefile.am,
src/lib/libbsp/sparc/leon3/Makefile.am: Added a generic smp wait
method to sparc and i386 bsps.
* src/lib/libbsp/shared/smp/bspsmp_wait_for.c: New file.
PR 1729/cpukit
* Makefile.am, configure.ac: Add next step in SMP support. This adds an
allocated array of the Per_CPU structures to support multiple cpus vs
a single instance of the structure which is still used if SMP support
is disabled. Configuration support is also added to explicitly enable
or disable SMP. But SMP can only be enabled for the CPUs which will
support it initially -- SPARC and i386. With the stub BSP support, a
BSP can be run as a single core SMP system from an RTEMS data
structure standpoint.
PR 1762/cpukit
* Makefile.am, preinstall.am, console/console.c, console/keyboard.c,
console/keyboard.h, console/pc_keyb.c, console/ps2_mouse.c,
console/vgainit.c: Made mouse parser engine generic. Now use generic
serial mouse driver. Moved many externs from C to .h.
* console/kbd_parser.c, console/serial_mouse_config.c: New files.
* console/mouse_parser.c, console/mouse_parser.h,
console/serial_mouse.c, console/serial_mouse.h: Removed.
* Makefile.am, preinstall.am: Update for generic interrupt support
changes.
* Makefile.am, preinstall.am, console/fb_vga.c: Switch to using
frame_buffer_ naming. Joel cleaned up formatting and removed tabs
that were there long before Roxana touched this file.
* console/fb_vga.h: Removed.
* Makefile.am, preinstall.am: Update for generic interrupt support.
* Makefile.am, preinstall.am: Install tty_drv.h
* Makefile.am: Add bspcmdline.c.
* include/bsp.h: Add boot command line interfaces.
* start/start.c: Save the multiboot command line. Pass the command
line to boot_card.
* start/start.S: Update for boot_card command line change.
* startup/bspstart.c: Initialise the command line.
* startup/bspcmdline.c: New.
* console/console.c, ide/idecfg.c: Add boot command line support.
* Makefile.am, startup/bspgetworkarea.c: Turn = into +=.
* Makefile.am: Eliminate bsp.am. Build startup files as side-effect
of building libbspstart.a, using automake-rules.
* clock/ckinit.c: include "../../../shared/clockdrv_shell.h".
* Makefile.am: Eliminate *_SOURCES.
* Makefile.am: Move noinst_LIBRARIES = libbsp.a before its
components.
* Makefile.am: Cleanup ../../shared/include/bootcard.h handling.
* Makefile.am: Cosmetics.
* Makefile.am, configure.ac, console/inch.c, console/keyboard.c,
include/bsp.h: Use standardized bsp_cleanup() which can optionally
print a message, poll for user to press key, and call bsp_reset().
Using this eliminates the various bsp_cleanup() implementations which
had their own implementation and variety of string constants.
* Makefile.am, configure.ac, startup/bspstart.c, startup/linkcmds: Add
bsp_get_work_area() implementation and use more of the BSP
Initialization Framework.
* startup/bspgetworkarea.c: New file.
* Makefile.am: Now named bspclean.c
