* configure.ac: Remove duplicate timer/Makefile in AC_CONFIG_FILES.
* network/Makefile.am: Use .$(OBJEXT) instead of .o.
* startup/bspstart.c: Per PR252 removed hack that tripled size of
RTEMS Workspace when POSIX is configured. This was probably done to
account for confdefs.h missing some application requirements.
* startup/linkcmds: In support of gcc 3.1, added one of more
of the sections .jcr, .rodata*, .data.*, .gnu.linkonce.s2.*,
.gnu.linkonce.sb2.*, and .gnu.linkonce.s.*. Spacing corrections
and direction of segments to memory regions may also have been
addressed. This was a sweep across all BSPs.
* include/bsp.h: include <libcpu/cpu.h>.
* configure.ac: Remove stray ';', PR 139.
* include/bsp.h: Include rtems/bspIo.h instead of bspIo.h.
* startup/linkcmds: Added _init and _fini.
* configure.in: Remove.
* start/Makefile.am: Dito.
* network/Makefile.am: Dito.
* console/console.c: Invoke BSP_uart_init() with enough arguments
now that more communication parameters are settable.
* startup/Makefile.am: Added idt.c since it has been moved libcpu/i386
to libbsp/i386/shared/irq.
* startup/linkcmds: Added lines so DWARF debug information
would be available. Otherwise gdb complains that the offsets
for the debug info are incorrect and doesn't load the files.
* start/Makefile.am: Remove AM_CPPFLAGS and GAS_CODE16 conditional.
* clock/Makefile.am, console/Makefile.am, network/Makefile.am,
location in libc.
that contains:
* Removes MKLIB
handling)
converted to automake.
because of the conversion to automake and replaced by a Makefile.am.
that converts the libbsp/i386 subdirectory to full automake.
that fixes the following problems:
1. Removing bogus ';' in some configure.in (cosmetical fix)
2. Moves GAS_CODE16 checks to libbsp/i386/*/configure.in (essential fix)
#2 was responsible for the gcc/binutils-2.9.5 choking while building for
the pc386.
which does the following:
patches
NOTES:
inside of those Makefiles.
directories.
to this at the moment.
that converts the i386 directory to automake.
NOTE: Ralf is unable to build any i386 BSPs. This was true before and
after this patch and appears (to Joel) to be a tool issue unrelated since
others can build i386 BSPs.
