Reflect changes to bsp.am.
* bsp_specs: Remove *lib:.
start/80386ex.h, start/80386ex.inc, start/macros.inc, start/start.S,
startup/bspstart.c, startup/linkcmds, startup/setvec.c,
timer/timer.c, timer/timerisr.S: URL for license changed.
PR 451/bsps
* startup/Makefile.am: Include shared i386 TTY driver in these BSPs.
PR 453/make_build
* startup/linkcmds: Added .eh_frame
* startup/linkcmds: Add FreeBSD SYSCTL() sections for networking.
* console/console.c: Removed __assert() which conflicts with newlib.
* network/network.c: Removed warnings.
* console/console.c, network/network.c: Removed warnings.
* startup/bspstart.c: Removed warnings.
* .cvsignore: Reformat.
Add autom4te*cache.
Remove autom4te.cache.
* configure.ac: Remove duplicate timer/Makefile in AC_CONFIG_FILES.
* network/Makefile.am: Use .$(OBJEXT) instead of .o.
* startup/bspstart.c: Per PR252 removed hack that tripled size of
RTEMS Workspace when POSIX is configured. This was probably done to
account for confdefs.h missing some application requirements.
* startup/linkcmds: In support of gcc 3.1, added one of more
of the sections .jcr, .rodata*, .data.*, .gnu.linkonce.s2.*,
.gnu.linkonce.sb2.*, and .gnu.linkonce.s.*. Spacing corrections
and direction of segments to memory regions may also have been
addressed. This was a sweep across all BSPs.
* include/bsp.h: include <libcpu/cpu.h>.
* configure.ac: Remove stray ';', PR 139.
* include/bsp.h: Include rtems/bspIo.h instead of bspIo.h.
* startup/linkcmds: Added _init and _fini.
* configure.in: Remove.
* start/Makefile.am: Dito.
* network/Makefile.am: Dito.
