* configure.ac: Remove explicit ampolish3 support (now in
RTEMS_BSP_CONFIGURE).
* configure.ac: Add ampolish3 support.
* Makefile.am: Add preinstall.am.
* Makefile.am: Add pci.rel.
* Makefile.am: Install/preinstall headers from ../../i386/shared.
* network/network.c: Remove #define KERNEL.
Include <errno.h>.
* Makefile.am: Add -D_KERNEL to network_CPPFLAGS.
* include/bsp.h: New header guard.
* clock/ckinit.c, console/console.c, include/bsp.h, startup/bspstart.c:
Moved irq.h to bsp subdirectory.
* clock/ckinit.c, console/console.c: Added support for
addition of parameter to ISRs.
* network/network.c: Modified parameter list to remove
warnings.
* network/network.c: Fix warnings.
* Makefile.am: Eliminate CFLAGS_OPTIMIZE_V.
* Makefile.am: Remove build-variant support.
* startup/linkcmds: Add gnu.linkonce.d and gcc_except_table sections.
* Makefile.am: Add -D__INSIDE_RTEMS_BSD_TCPIP_STACK__ for network.
PR 610/bsps
* Makefile.am: Add include/tm27.h, Cosmetics.
* include/tm27.h: Final cosmetics.
* include/tm27.h: New.
PR 613/bsps
PR 614/bsps
* timer/timerisr.S: Include <rtems/asm.h> instead of <asm.h>.
* network/network.c: Include <rtems/asm.h> instead of <asm.h>.
* clock/ckinit.c, include/bsp.h, startup/bspstart.c, timer/timer.c:
Convert to using c99 fixed size types.
* Makefile.am: Reflect changes to bsp.am.
Preinstall dist_project_lib*.
* Makefile.am: Use CPPASCOMPILE instead of CCASCOMPILE.
* Makefile.am: Pickup files from ../../i386/shared instead of
../shared. Reformat.
network/Makefile.am, startup/Makefile.am, timer/Makefile.am,
wrapup/Makefile.am. Use automake compilation rules.
* clock/Makefile.am, console/Makefile.am, network/Makefile.am,
startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am: Remove.
* configure.ac: Add nostdinc to AUTOMAKE_OPTIONS.
Add RTEMS_PROG_CCAS.
* wrapup/Makefile.am: Reflect changes to libcpu.
* startup/Makefile.am: Ditto.
* start/Makefile.am: Remove.
* Makefile.am: Merge-in start/Makefile.am.
* wrapup/Makefile.am: Eliminate $(LIB).
Use noinst_DATA to trigger building libbsp.a.
* network/Makefile.am: Cosmetics.
