by newlib.
Also removed bsp_postdriver_hook() from every bsp possible and moved
to shared version.
based on the GNU tools. This usually involved correcting the
type of bsp_start(), bsp_cleanup(), adjusting the start code to
call the right start routine (the shared boot_card()), and then
removing code from bsp_start() which was performed in the new
boot_card()/main() path.
"gmake debug".
subdirectory Makefiles.
used.
individual Makefile.
problem (reported by Eric)
by Ralf Corsepius
enclose.
interpreted at the right point per Eric Norum's discovery:
The problem with the my previous `fix' for adding linker commands
was with the ordering of the options to the linker.
For example, to make a larger heap size, the application Makefile would
CFLAGS_LD = -Wl,--defsym -Wl,HeapSize=0x40000
The command passed to the linker would be :
m68k-rtems-ld .... -T xxx/linkcmds .... --defsym HeapSize=0x40000 .....
This doesn't work because the script in linkcmds inserts a default
value for HeapSize if HeapSize is not defined by the time the linker
looks at the linkcmds script.
The solution seems to be to move the -T linkcmds%s in the bsp_specs
file out of the link specfication and into the lib specification -- a
little unorthodox, perhaps, but it seems to work!
switch which lets the user specify a different linker script.
to lib/include.
returned an error to using a single shared copy of this file.
be resolved.
added standard comments about driver entries.
