* | headers updated to reflect new style copyright notice as part | Joel Sherrill | 1997-04-22 | 9 | -45/+45 |
* | Fixed path which points to shared directory for all BSPs. | Joel Sherrill | 1997-04-16 | 1 | -1/+1 |
* | Switched all bsps which had an implementation of sbrk.c which only | Joel Sherrill | 1997-04-15 | 1 | -1/+1 |
| | | | | returned an error to using a single shared copy of this file. | ||||
* | This set of changes is the build of what was required to convert to | Joel Sherrill | 1997-04-01 | 7 | -0/+340 |
| | | | | | | | | | | | | | | | | | | | | GNU autoconf. This is the first large step in allowing an RTEMS user to perform a one-tree build (per crossgcc FAQ) including RTEMS in the build process. With this change RTEMS is configured in built in the same style as the GNU tools, yet retains the basic structure of its traditional Makefiles (ala Tony Bennett). Jiri Gaisler (jgais@wd.estec.esa.nl) deserves (and received) a big thank you for doing this. There are still issues to be resolved but as of this commit, all target which can be built on a linux host have been using a modified version of the source Jiri submitted. This source was merged and most targets built in the tree before this commit. There are some issues which remain to be resolved but they are primarily related to host OS dependencies, script issues, the use of gawk for hack_specs, and the dependence on gcc snapshots. These will be resolved. | ||||
* | All RTEMS system call implementation renamed to be __rtems_*. | Joel Sherrill | 1997-01-29 | 1 | -4/+4 |
* | new file used by gcc 2.8.x -specs option | Joel Sherrill | 1997-01-28 | 1 | -0/+34 |
* | updated to format of 3.6.0 | Joel Sherrill | 1996-10-15 | 2 | -42/+102 |
* | updated to format of 3.6.0 console drivers | Joel Sherrill | 1996-10-15 | 1 | -51/+111 |
* | updated to format of 3.6.0 clock drivers | Joel Sherrill | 1996-10-15 | 1 | -24/+83 |
* | new file | Joel Sherrill | 1996-10-15 | 1 | -0/+8 |
* | reference to Force CPU-386 removed. | Joel Sherrill | 1996-10-15 | 1 | -3/+20 |
| | | | | added standard comments about driver entries. | ||||
* | initial version from Erik | Joel Sherrill | 1996-10-15 | 10 | -0/+1038 |
