* configure.in: Remove.
* start/Makefile.am: Dito.
* network/Makefile.am: Dito.
* console/console.c: Invoke BSP_uart_init() with enough arguments
now that more communication parameters are settable.
* startup/Makefile.am: Added idt.c since it has been moved libcpu/i386
to libbsp/i386/shared/irq.
* startup/linkcmds: Added lines so DWARF debug information
would be available. Otherwise gdb complains that the offsets
for the debug info are incorrect and doesn't load the files.
* start/Makefile.am: Remove AM_CPPFLAGS and GAS_CODE16 conditional.
* clock/Makefile.am, console/Makefile.am, network/Makefile.am,
location in libc.
that contains:
* Removes MKLIB
handling)
converted to automake.
because of the conversion to automake and replaced by a Makefile.am.
that converts the libbsp/i386 subdirectory to full automake.
that fixes the following problems:
1. Removing bogus ';' in some configure.in (cosmetical fix)
2. Moves GAS_CODE16 checks to libbsp/i386/*/configure.in (essential fix)
#2 was responsible for the gcc/binutils-2.9.5 choking while building for
the pc386.
which does the following:
patches
NOTES:
inside of those Makefiles.
directories.
to this at the moment.
that converts the i386 directory to automake.
NOTE: Ralf is unable to build any i386 BSPs. This was true before and
after this patch and appears (to Joel) to be a tool issue unrelated since
others can build i386 BSPs.
*.cfg files.
dependencies
automake and RTEMS make rules
convention)
performs automatically.
WARNING:
Makefile.ams.
reported bugs in the start code.
conditional that should have been fixed long ago.
to fix problem reported by Ralf Corsepius <corsepiu@faw.uni-ulm.de>.
Date: Fri, 30 Jul 1999 14:53:20 -0500 (CDT)
it is used like this in i386ex/start/start.S
/* set up same values in cache */
start.S: movw $0xFFFB, SYM(i8259s_cache)
I am heading out the door. Any other ideas what could have tripped this?
This instruction appears in a .code16 section. In a .code16 section,
current versions of gas assume that all addresses are 16 bits unless
told otherwise.
If you change the line to
addr32 movw $0xFFFB, SYM(i8259s_cache)
then you will get a 32 bit address reference.
You may want to use addr32 only when NEW_GAS is defined.
CHANGES
autoconf check
autoconf check
$(prefix)/<bsp>/make/bsp.cfg
compatible.
Makefile.ins
dependencies of "Makefile".
--enable-maintainer-mode.
ncurses, and zlib for RTEMS.
link even if they do not actually support Ada interrupts.
jmp relative offset from .reset section.
future.
cd <rtems-source-tree>
1) ./c/src/lib/libbsp/i386/i386ex/startup/Makefile.in
> preinstall:
> $(INSTALL_CHANGE) ${IMPORT_SRC} .
> # ${CP} ${IMPORT_SRC} .
This fragment is broken, because IMPORT_SRC is always empty.
IMO, the fix would be to remove this fragment or to replace it with
test -z "${IMPORT_SRC}" || cp ${IMPORT_SRC} .
if an external shell variable IMPORT_SRC shall be supported by this
Makefile, which IMO should not be done.
all bsp_specs.
