* startup/linkcmds: Add wildcard to gcc_except_table section so
programs compiled with gcc 4.3.x can link.
* startup/linkcmds: Handle .data.* sections
* startup/linkcmds: Add gnu.linkonce.d and gcc_except_table sections.
start/80386ex.h, start/80386ex.inc, start/macros.inc, start/start.S,
startup/bspstart.c, startup/linkcmds, startup/setvec.c,
timer/timer.c, timer/timerisr.S: URL for license changed.
PR 453/make_build
* startup/linkcmds: Added .eh_frame
* startup/linkcmds: Add FreeBSD SYSCTL() sections for networking.
* startup/linkcmds: In support of gcc 3.1, added one of more
of the sections .jcr, .rodata*, .data.*, .gnu.linkonce.s2.*,
.gnu.linkonce.sb2.*, and .gnu.linkonce.s.*. Spacing corrections
and direction of segments to memory regions may also have been
addressed. This was a sweep across all BSPs.
* startup/linkcmds: Added _init and _fini.
* startup/linkcmds: Added lines so DWARF debug information
would be available. Otherwise gdb complains that the offsets
for the debug info are incorrect and doesn't load the files.
i386ex bsp up to date.
1) A 'hlt' instruction is coded in case of a return from boot_card in
start.s.
Also removed bsp_postdriver_hook() from every bsp possible and moved
to shared version.
enclose.
