* | Update from Erik Ivanenko <erik.ivanenko@utoronto.ca> to bring the | Joel Sherrill | 1998-09-21 | 1 | -4/+15 |
| | | | | | | | i386ex bsp up to date. 1) A 'hlt' instruction is coded in case of a return from boot_card in start.s. | ||||
* | Patch from Eric Valette <valette@crf.canon.fr> which brings the i386ex BSP | Joel Sherrill | 1998-08-05 | 1 | -1/+4 |
| | | | | inline with the new IRQ structure. | ||||
* | Numerous changes which in total greatly reduced the amount of source | Joel Sherrill | 1998-04-15 | 1 | -25/+0 |
| | | | | | | | | | | | | code in each BSP's bspstart.c. These changes were: + confdefs.h now knows libio's semaphore requirements + shared/main.c now copies Configuration to BSP_Configuration + shared/main.c fills in the Cpu_table with default values This removed the need for rtems_libio_config() and the constant BSP_LIBIO_MAX_FDS in every BSP. Plus now the maximum number of open files can now be set on the gcc command line. | ||||
* | Transitioned to shared bsp_libc_init() and cleaned up comments. | Joel Sherrill | 1998-04-15 | 1 | -45/+21 |
* | Per suggestion from Eric Norum, went from one initial extension set | Joel Sherrill | 1998-04-15 | 1 | -13/+0 |
| | | | | | | to multiple. This lets the stack check extension be installed at system initialization time and avoids the BSP having to even know about its existence. | ||||
* | Stack checker extension now accounted for in confdefs.h | Joel Sherrill | 1998-04-14 | 1 | -4/+2 |
* | Now accounts for region used by RTEMS malloc and extension used | Joel Sherrill | 1998-04-14 | 1 | -14/+0 |
| | | | | by newlib. | ||||
* | Update from "erik.ivanenko" <erik.ivanenko@utoronto.ca>. | Joel Sherrill | 1998-03-30 | 1 | -67/+47 |
| | | | | | Also removed bsp_postdriver_hook() from every bsp possible and moved to shared version. | ||||
* | Switch to using a shared main() for all of the embedded BSPs | Joel Sherrill | 1998-03-21 | 1 | -14/+1 |
| | | | | | | | | based on the GNU tools. This usually involved correcting the type of bsp_start(), bsp_cleanup(), adjusting the start code to call the right start routine (the shared boot_card()), and then removing code from bsp_start() which was performed in the new boot_card()/main() path. | ||||
* | updated copyright to 1998 | Joel Sherrill | 1998-02-17 | 1 | -1/+1 |
* | Fixed typo in the pointer to the license terms. | Joel Sherrill | 1997-10-08 | 1 | -2/+2 |
* | headers updated to reflect new style copyright notice as part | Joel Sherrill | 1997-04-22 | 1 | -5/+5 |
* | All RTEMS system call implementation renamed to be __rtems_*. | Joel Sherrill | 1997-01-29 | 1 | -4/+4 |
* | updated to format of 3.6.0 | Joel Sherrill | 1996-10-15 | 1 | -31/+100 |
* | initial version from Erik | Joel Sherrill | 1996-10-15 | 1 | -0/+160 |
