* include/bsp.h, include/tm27.h, network/network.c:
* include/bsp.h: Remove unnecessary variables and EXTERN magic.
* include/bsp.h: Remove unnecessary boilerplate comments.
* clock/ckinit.c, include/bsp.h, startup/bspstart.c: Eliminate copies
of the Configuration Table. Use the RTEMS provided accessor macros to
obtain configuration fields.
* include/bsp.h, startup/bspstart.c: Move interrupt_stack_size field
from CPU Table to Configuration Table. Eliminate CPU Table from all
ports. Delete references to CPU Table in all forms.
* include/bsp.h: New header guard.
* clock/ckinit.c, console/console.c, include/bsp.h, startup/bspstart.c:
Moved irq.h to bsp subdirectory.
* include/tm27.h: New.
PR 613/bsps
PR 614/bsps
* network/network.c: Include <rtems/asm.h> instead of <asm.h>.
* clock/ckinit.c, include/bsp.h, startup/bspstart.c, timer/timer.c:
Convert to using c99 fixed size types.
start/80386ex.h, start/80386ex.inc, start/macros.inc, start/start.S,
startup/bspstart.c, startup/linkcmds, startup/setvec.c,
timer/timer.c, timer/timerisr.S: URL for license changed.
* include/bsp.h: include <libcpu/cpu.h>.
* include/bsp.h: Include rtems/bspIo.h instead of bspIo.h.
* start/Makefile.am: Dito.
* network/Makefile.am: Dito.
conditional that should have been fixed long ago.
i386ex bsp up to date.
1) A 'hlt' instruction is coded in case of a return from boot_card in
start.s.
inline with the new IRQ structure.
Enabled on the pc386.
added standard comments about driver entries.
like signal dispatching.
IDLE task priority changed from 0 to 255 during initialization.
