* | Patches rtems-rc-20000204-0.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-02-08 | 1 | -3/+5 |
| | | | | | | | | | | | | | | | | | that contains: * Removes remaining (now illegal) references to $(SRC) from a couple of Makefile.ams * Removes duplicate AC_CONFIG_SUBDIRS macro from c/configure.in * Moves ENABLE_LIBCDIR into RTEMS_PROG_C[C|XX]_FOR_TARGET (hides LIBCDIR from most configure scripts, i.e. LIBCDIR becomes less visible) * Adds RTEMS_PROG_C[C|XX]_FOR_TARGET and RTEMS_CANONICALIZE_TOOLS to libbsp/*/configure.ins (A minor bug in previous implementations, which only has an impact when switching to GNU/Cygnus canonicalization) * Cleans up several bogus comments. * Removes MKLIB * Switches the version number to 4.5.0 (for testing version number handling) | ||||
* | Patch rtems-rc-20000104-15.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-01-12 | 1 | -0/+4 |
| | | | | | | | | | | that fixes the following problems: 1. Removing bogus ';' in some configure.in (cosmetical fix) 2. Moves GAS_CODE16 checks to libbsp/i386/*/configure.in (essential fix) #2 was responsible for the gcc/binutils-2.9.5 choking while building for the pc386. | ||||
* | Patch rtems-rc-20000104-11.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-01-10 | 1 | -0/+36 |
that converts the i386 directory to automake. NOTE: Ralf is unable to build any i386 BSPs. This was true before and after this patch and appears (to Joel) to be a tool issue unrelated since others can build i386 BSPs. |
