1999-10-05 | Removed targets and configurations that are no longer functional | Joel Sherrill | 1 | -46/+0 | |
and not likely to become so. Comments on each configuration are below. + Force CPU386 - This BSP was developed as part of the initial port of RTEMS to the i386. This board has been unavailable for a long time now. + GO32 - This BSP and some CPU code supported djgpp v1.x. This version is now quite old. No one has stepped forward to update the code to v2.x which may be technically impossible anyway. More importantly, go32 has been superceded by the pc386 BSP. | |||||
1998-02-17 | updated copyright to 1998 | Joel Sherrill | 1 | -1/+1 | |
1997-10-08 | Fixed typo in the pointer to the license terms. | Joel Sherrill | 1 | -2/+2 | |
1997-04-22 | headers updated to reflect new style copyright notice as part | Joel Sherrill | 1 | -5/+5 | |
of switching to the modified GNU GPL. | |||||
1995-07-20 | updating go32 to make timer more accurate | Joel Sherrill | 1 | -23/+2 | |
1995-07-18 | committing for rtems-3.2.01 snapshot | Joel Sherrill | 1 | -4/+4 | |
1995-07-12 | Ada95, gnat, go32 | Joel Sherrill | 1 | -0/+67 | |
