path: root/c/src/lib/libbsp/i386/force386/startup/bspstart.c (follow)
* Numerous changes which in total greatly reduced the amount of sourceJoel Sherrill1998-04-151-23/+0
| | | | | | | | | | | | code in each BSP's bspstart.c. These changes were: + confdefs.h now knows libio's semaphore requirements + shared/main.c now copies Configuration to BSP_Configuration + shared/main.c fills in the Cpu_table with default values This removed the need for rtems_libio_config() and the constant BSP_LIBIO_MAX_FDS in every BSP. Plus now the maximum number of open files can now be set on the gcc command line.
* Transitioned to shared bsp_libc_init() and cleaned up comments.Joel Sherrill1998-04-151-44/+19
* Per suggestion from Eric Norum, went from one initial extension setJoel Sherrill1998-04-151-13/+0
| | | | | | to multiple. This lets the stack check extension be installed at system initialization time and avoids the BSP having to even know about its existence.
* Stack checker extension now accounted for in confdefs.hJoel Sherrill1998-04-141-8/+0
* Now accounts for region used by RTEMS malloc and extension usedJoel Sherrill1998-04-141-14/+0
| | | | by newlib.
* Moved bsp_postdriver_hook() to a shared file and made it a commonJoel Sherrill1998-03-301-27/+2
| | | | component.
* Switch to using a shared main() for all of the embedded BSPsJoel Sherrill1998-03-211-15/+1
| | | | | | | | based on the GNU tools. This usually involved correcting the type of bsp_start(), bsp_cleanup(), adjusting the start code to call the right start routine (the shared boot_card()), and then removing code from bsp_start() which was performed in the new boot_card()/main() path.
* All RTEMS system call implementation renamed to be __rtems_*.Joel Sherrill1997-01-291-4/+4
* added initial posix configuration supportJoel Sherrill1996-05-281-1/+1
* Dispersal of internal thread handler resulted in the SYSI task beingJoel Sherrill1996-02-211-1/+1
| | | | | | only required in a multiprocessor system. It was replace by the MPCI Receive Server. As a result, the CPU Table field for extra stack for the SYSI task was changed to be extra stack for the MPCI Receive Server.
* SPARC port passes all testsJoel Sherrill1995-10-301-4/+7
* Minor bug fixes to get all targets compilable and running. TheJoel Sherrill1995-09-191-5/+30
* The word "RTEMS" almost completely removed from the core.Joel Sherrill1995-09-111-3/+56
* Initial revisionJoel Sherrill1995-05-111-0/+144
