this week until now.
It consists of 3 parts:
1. a patch
2. a perl script (acpolish)
plural).
configure scripts etc.
added by acpolish.
To apply this:
./rtems-polish.sh
Later:
cvs add contrib
cvs add contrib/acpolish
cvs commit
of theses targets...
subdirectory Makefiles.
used.
individual Makefile.
problem (reported by Eric)
be resolved.
