* shared/comm/tty_drv.c: Remove all references to
console_reserve_resources and termios_reserve_resources.
* shared/irq/irq.c: test for non-NULL-ness before calling
'on'/'off' methods so that users don't have to provide
no-ops if they don't want this feature.
PR 1257/bsps
* shared/irq/idt.c, shared/irq/irq.c, shared/irq/irq_init.c: Code
outside of cpukit should use the public API for
rtems_interrupt_disable/rtems_interrupt_enable. By bypassing the
public API and directly accessing _CPU_ISR_Disable and
_CPU_ISR_Enable, they were bypassing the compiler memory barrier
directive which could lead to problems. This patch also changes the
type of the variable passed into these routines and addresses minor
style issues.
* shared/pci/pcibios.c, shared/pci/pcibios.h:
Reflect changes to rtems/pci.h. Convert to using
stdint fixed-size types.
* shared/irq/idt.c: unsigned limits to match with
i386_get_info_from_IDTR.
-1 on failure, not just non-zero status. I found that
some driver(s) [e.g. dec21140] explicitely check for -1.
* shared/irq/idt.c: Reflect API changes.
* shared/pci/pcibios.c: replaced pci_find_device implementation by a
pcibios call which already provides the functionality
* shared/comm/i386_io.h, shared/comm/tty_drv.c,
shared/comm/tty_drv.h: Remove CVS Log.
* Makefile.am: Merge-in shared/Makefile.am.
* ChangeLog: Merge-in shared/ChangeLog.
* configure.ac: Remove shared/Makefile.am.
* shared/pci/pcibios.c, shared/pci/pcibios.h: Make PCI initialize
function part of the unified PCI API as pci_initialize().
* pc386/console/vgainit.c, pc386/wd8003/wd8003.c, shared/comm/uart.c:
Fix errors caught by gcc 4.x.
* acinclude.m4: Regenerate.
* configure.ac: RTEMS_CHECK_BSPDIR([$RTEMS_BSP_FAMILY]).
* Makefile.am: Use @RTEMS_BSP_FAMILY@ instead of
$(RTEMS_BSP_FAMILY).
* configure.ac: Remove shared/io/Makefile, shared/comm/Makefile,
shared/pci/Makefile, shared/irq/Makefile.
* acinclude.m4: Reflect changes to bootstrap.
* configure.ac: Remove RTEMS_CHECK_CUSTON_BSP.
* .cvsignore: Reformat.
Add autom4te*cache.
Remove autom4te.cache.
* configure.in: Remove.
* acinclude.m4: New file.
* pc386/console/console.c, pc386/console/serial_mouse.c,
pc386/console/vgainit.c, shared/comm/tty_drv.c: Remove warnings.
