* shmsupp/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* tty/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* start/start.S: Per PR329 now compiles with GNU tools.
* startup/linkcmds: New file. Now almost links.
* include/Makefile.am: Fix broken preinstall-deps.
* pxfl/.cvsignore, pxfl/Makefile.in, pxfl/README,
pxfl/floss-bsp.h: Removed.
* .cvsignore: Reformat.
Add autom4te*cache.
Remove autom4te.cache.
* shmsupp/Makefile.am: Use .$(OBJEXT) instead of .o.
* tty/Makefile.am: Use .$(OBJEXT) instead of .o.
* start/Makefile.am: Eliminate PGMS.
* Makefile.am, bsp_specs: Now this target almost compiles again.
* configure.ac: Remove AC_EXEEXT (obsolete).
* tty/Makefile.am: Remove AUTOMAKE_OPTIONS.
* configure.ac: Add RTEMS_BSPOPTS_*(SIMHPPA_FAST_IDLE),
remove RTEMS_OUTPUT_BUILD_SUBDIRS.
* configure.in: Remove.
* acinclude.m4: New file.
* .cvsignore: Add stamp-h
* config.h.in: Automatically generated. Remove from CVS.
* configure.in, Makefile.am: ACLOCAL_AMFLAGS= -I $(RTEMS_TOPdir)/macros.
* include/bsp.h: tty_* renamed to console_*.
* tty/tty.c: Ditto.
* shmsupp/addrconv.c: Typo fixed.
* wrapup/Makefile.am: Merge startup not start directory.
* shmsupp/Makefile.am, start/Makefile.am, startup/Makefile.am,
tty/Makefile.am, wrapup/Makefile.am: Include compile.am
cpuopts.h.
exec/configure.in, only.
quoting bugs in autoconf).
formating changes :)
that contains:
* Removes MKLIB
handling)
converted to automake.
that should not have been.
that contains:
regarded as bugs).
now works).
* removes libbsp/bare/wrapup
* Further cleanups
that converts the hppa1.1 directory to automake.
NOTE:
* Due to not having a toolchain (gcc refuses to build) this patch is
untested.
* I omited/deactivated the pxfl subdirectory, because I don't
understand how it supposed to work.
Joel's note: It was right to ignore the pxfl directory. It should be
removed one the BSPs are moved outside the tree. This was an old hack.
