* hppa1.1/.cvsignore, hppa1.1/ChangeLog, hppa1.1/Makefile.am,
hppa1.1/acinclude.m4, hppa1.1/configure.ac,
hppa1.1/simhppa/.cvsignore, hppa1.1/simhppa/ChangeLog,
hppa1.1/simhppa/Makefile.am, hppa1.1/simhppa/bsp_specs,
hppa1.1/simhppa/configure.ac, hppa1.1/simhppa/times,
hppa1.1/simhppa/include/.cvsignore,
hppa1.1/simhppa/include/Makefile.am, hppa1.1/simhppa/include/bsp.h,
hppa1.1/simhppa/include/ttydrv.h, hppa1.1/simhppa/shmsupp/.cvsignore,
hppa1.1/simhppa/shmsupp/Makefile.am, hppa1.1/simhppa/shmsupp/README,
hppa1.1/simhppa/shmsupp/addrconv.c,
hppa1.1/simhppa/shmsupp/cause_intr.c,
hppa1.1/simhppa/shmsupp/getcfg.c, hppa1.1/simhppa/shmsupp/lock.c,
hppa1.1/simhppa/shmsupp/mpisr.c, hppa1.1/simhppa/start/.cvsignore,
hppa1.1/simhppa/start/Makefile.am, hppa1.1/simhppa/start/start.S,
hppa1.1/simhppa/startup/.cvsignore,
hppa1.1/simhppa/startup/Makefile.am,
hppa1.1/simhppa/startup/bspclean.c,
hppa1.1/simhppa/startup/bspstart.c, hppa1.1/simhppa/startup/linkcmds,
hppa1.1/simhppa/startup/setvec.c, hppa1.1/simhppa/tools/.cvsignore,
hppa1.1/simhppa/tools/ChangeLog, hppa1.1/simhppa/tools/Makefile.am,
hppa1.1/simhppa/tools/configure.ac,
hppa1.1/simhppa/tools/print_dump.c, hppa1.1/simhppa/tty/.cvsignore,
hppa1.1/simhppa/tty/Makefile.am, hppa1.1/simhppa/tty/tty.c,
hppa1.1/simhppa/wrapup/.cvsignore,
hppa1.1/simhppa/wrapup/Makefile.am: Removed.
* bsp_specs: Remove *lib:.
* include/bsp.h, shmsupp/addrconv.c, shmsupp/cause_intr.c,
shmsupp/getcfg.c, shmsupp/lock.c, shmsupp/mpisr.c,
startup/bspclean.c, startup/bspstart.c, startup/setvec.c,
tools/print_dump.c, tty/tty.c: URL for license changed.
shmsupp/Makefile.am: Reflect having moved automake.
tty/Makefile.am: Reflect having moved automake.
* startup/linkcmds: Add FreeBSD SYSCTL() sections for networking.
* shmsupp/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* tty/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* start/start.S: Per PR329 now compiles with GNU tools.
* startup/linkcmds: New file. Now almost links.
* include/Makefile.am: Fix broken preinstall-deps.
* .cvsignore: Reformat.
Add autom4te*cache.
Remove autom4te.cache.
* shmsupp/Makefile.am: Use .$(OBJEXT) instead of .o.
* tty/Makefile.am: Use .$(OBJEXT) instead of .o.
* start/Makefile.am: Eliminate PGMS.
* Makefile.am, bsp_specs: Now this target almost compiles again.
* configure.ac: Remove AC_EXEEXT (obsolete).
* tty/Makefile.am: Remove AUTOMAKE_OPTIONS.
* configure.ac: Add RTEMS_BSPOPTS_*(SIMHPPA_FAST_IDLE),
remove RTEMS_OUTPUT_BUILD_SUBDIRS.
* configure.in: Remove.
* .cvsignore: Add stamp-h
* config.h.in: Automatically generated. Remove from CVS.
* configure.in, Makefile.am: ACLOCAL_AMFLAGS= -I $(RTEMS_TOPdir)/macros.
* include/bsp.h: tty_* renamed to console_*.
* tty/tty.c: Ditto.
* shmsupp/addrconv.c: Typo fixed.
* wrapup/Makefile.am: Merge startup not start directory.
* shmsupp/Makefile.am, start/Makefile.am, startup/Makefile.am,
tty/Makefile.am, wrapup/Makefile.am: Include compile.am
