2003-09-26 | 2003-09-26 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -31/+0 | |
* hppa1.1/.cvsignore, hppa1.1/ChangeLog, hppa1.1/Makefile.am, hppa1.1/acinclude.m4, hppa1.1/configure.ac, hppa1.1/simhppa/.cvsignore, hppa1.1/simhppa/ChangeLog, hppa1.1/simhppa/Makefile.am, hppa1.1/simhppa/bsp_specs, hppa1.1/simhppa/configure.ac, hppa1.1/simhppa/times, hppa1.1/simhppa/include/.cvsignore, hppa1.1/simhppa/include/Makefile.am, hppa1.1/simhppa/include/bsp.h, hppa1.1/simhppa/include/ttydrv.h, hppa1.1/simhppa/shmsupp/.cvsignore, hppa1.1/simhppa/shmsupp/Makefile.am, hppa1.1/simhppa/shmsupp/README, hppa1.1/simhppa/shmsupp/addrconv.c, hppa1.1/simhppa/shmsupp/cause_intr.c, hppa1.1/simhppa/shmsupp/getcfg.c, hppa1.1/simhppa/shmsupp/lock.c, hppa1.1/simhppa/shmsupp/mpisr.c, hppa1.1/simhppa/start/.cvsignore, hppa1.1/simhppa/start/Makefile.am, hppa1.1/simhppa/start/start.S, hppa1.1/simhppa/startup/.cvsignore, hppa1.1/simhppa/startup/Makefile.am, hppa1.1/simhppa/startup/bspclean.c, hppa1.1/simhppa/startup/bspstart.c, hppa1.1/simhppa/startup/linkcmds, hppa1.1/simhppa/startup/setvec.c, hppa1.1/simhppa/tools/.cvsignore, hppa1.1/simhppa/tools/ChangeLog, hppa1.1/simhppa/tools/Makefile.am, hppa1.1/simhppa/tools/configure.ac, hppa1.1/simhppa/tools/print_dump.c, hppa1.1/simhppa/tty/.cvsignore, hppa1.1/simhppa/tty/Makefile.am, hppa1.1/simhppa/tty/tty.c, hppa1.1/simhppa/wrapup/.cvsignore, hppa1.1/simhppa/wrapup/Makefile.am: Removed. | |||||
2003-08-16 | 2003-08-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -3/+3 | |
Makefile.am: Reflect having moved automake. include/Makefile.am: Reflect having moved automake. shmsupp/Makefile.am: Reflect having moved automake. start/Makefile.am: Reflect having moved automake. startup/Makefile.am: Reflect having moved automake. tty/Makefile.am: Reflect having moved automake. wrapup/Makefile.am: Reflect having moved automake. | |||||
2003-01-15 | 2003-01-15 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -1/+0 | |
* shmsupp/Makefile.am: Don't include @RTEMS_BSP@.cfg. * start/Makefile.am: Don't include @RTEMS_BSP@.cfg. * startup/Makefile.am: Don't include @RTEMS_BSP@.cfg. * tty/Makefile.am: Don't include @RTEMS_BSP@.cfg. | |||||
2002-08-11 | 2002-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -1/+1 | |
* shmsupp/Makefile.am: Use .$(OBJEXT) instead of .o. * start/Makefile.am: Use .$(OBJEXT) instead of .o. * startup/Makefile.am: Use .$(OBJEXT) instead of .o. * tty/Makefile.am: Use .$(OBJEXT) instead of .o. * wrapup/Makefile.am: Use .$(OBJEXT) instead of .o. | |||||
2002-03-28 | 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1 | -1/+0 | |
* configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * include/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. * shmsupp/Makefile.am: Remove AUTOMAKE_OPTIONS. * start/Makefile.am: Remove AUTOMAKE_OPTIONS. * startup/Makefile.am: Remove AUTOMAKE_OPTIONS. * tty/Makefile.am: Remove AUTOMAKE_OPTIONS. * wrapup/Makefile.am: Remove AUTOMAKE_OPTIONS. | |||||
2000-09-05 | 2000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1 | -0/+1 | |
* shmsupp/Makefile.am, start/Makefile.am, startup/Makefile.am, tty/Makefile.am, wrapup/Makefile.am: Include compile.am | |||||
2000-06-12 | Merged from 4.5.0-beta3a | Joel Sherrill | 1 | -2/+2 | |
2000-01-31 | Patches rtems-rc-20000118-3.diff and rtems-rc-20000118-4.diff from | Joel Sherrill | 1 | -8/+9 | |
Ralf Corsepius <corsepiu@faw.uni-ulm.de> that contain: * Modifications, (minor) corrections, cleanups to most existing Makefile.ams * Adds automake support to all remaining BSPs which have not yet been converted to automake. * Makefile.am for all remaining wrapup/Makefile.ams | |||||
2000-01-10 | Patch rtems-rc-20000104-3.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1 | -7/+2 | |
that converts the sparc directory to automake. Ralf's note: The implementation of libbsp/sparc/* gives a nearly minimal example of the new configuration scheme. | |||||
2000-01-10 | Patch rtems-rc-20000104-2.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1 | -0/+36 | |
that converts nearly all of libbsp/sh to automake. Comments follow: 1. Almost full automake support for the libbsp/sh/ subdirectories (exception libbsp/sh/gensh*/wrapup/*) 2. Fixes for libbsp/bare/* 3. Updates to libbsp/* configuration which supports old (autoconf/deep configuration) and new (automake/flat/cascaded configuration) style configuration of libbsp/<cpu>/* |
