path: root/c/src/lib/libbsp/hppa1.1/simhppa/tools (unfollow)
1998-01-20Removed CONFIG_DIR and PROJECT_HOME directories.Joel Sherrill1-1/+1
1997-12-10Modified a lot of files to take a first cut at supporting building fromJoel Sherrill1-1/+4
any directory in the build tree. The only variable which must be set before the command "gmake" is invoked is RTEMS_BSP (e.g. RTEMS_BSP=erc32).
1997-10-08Fixed typo in the pointer to the license terms.Joel Sherrill1-2/+2
1997-04-22updated with new license information per Tony Bennett.Joel Sherrill1-12/+5
1997-04-01This set of changes is the build of what was required to convert toJoel Sherrill1-0/+51
