2003-09-26 | 2003-09-26 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -71/+0 | |
* hppa1.1/.cvsignore, hppa1.1/ChangeLog, hppa1.1/Makefile.am, hppa1.1/acinclude.m4, hppa1.1/configure.ac, hppa1.1/simhppa/.cvsignore, hppa1.1/simhppa/ChangeLog, hppa1.1/simhppa/Makefile.am, hppa1.1/simhppa/bsp_specs, hppa1.1/simhppa/configure.ac, hppa1.1/simhppa/times, hppa1.1/simhppa/include/.cvsignore, hppa1.1/simhppa/include/Makefile.am, hppa1.1/simhppa/include/bsp.h, hppa1.1/simhppa/include/ttydrv.h, hppa1.1/simhppa/shmsupp/.cvsignore, hppa1.1/simhppa/shmsupp/Makefile.am, hppa1.1/simhppa/shmsupp/README, hppa1.1/simhppa/shmsupp/addrconv.c, hppa1.1/simhppa/shmsupp/cause_intr.c, hppa1.1/simhppa/shmsupp/getcfg.c, hppa1.1/simhppa/shmsupp/lock.c, hppa1.1/simhppa/shmsupp/mpisr.c, hppa1.1/simhppa/start/.cvsignore, hppa1.1/simhppa/start/Makefile.am, hppa1.1/simhppa/start/start.S, hppa1.1/simhppa/startup/.cvsignore, hppa1.1/simhppa/startup/Makefile.am, hppa1.1/simhppa/startup/bspclean.c, hppa1.1/simhppa/startup/bspstart.c, hppa1.1/simhppa/startup/linkcmds, hppa1.1/simhppa/startup/setvec.c, hppa1.1/simhppa/tools/.cvsignore, hppa1.1/simhppa/tools/ChangeLog, hppa1.1/simhppa/tools/Makefile.am, hppa1.1/simhppa/tools/configure.ac, hppa1.1/simhppa/tools/print_dump.c, hppa1.1/simhppa/tty/.cvsignore, hppa1.1/simhppa/tty/Makefile.am, hppa1.1/simhppa/tty/tty.c, hppa1.1/simhppa/wrapup/.cvsignore, hppa1.1/simhppa/wrapup/Makefile.am: Removed. | |||||
2003-08-18 | 2003-08-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+4 | |
* Makefile.am: Reflect having moved aclocal/. | |||||
2003-08-18 | Fix broken ChangeLog entries. | Ralf Corsepius | 1 | -1/+1 | |
2003-08-16 | 2003-08-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+4 | |
Makefile.am: Reflect having moved automake. | |||||
2003-08-11 | 2003-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+4 | |
* configure.ac: Use rtems-bugs@rtems.com as bug report email address. | |||||
2003-03-11 | Merger from rtems-4-6-branch. | Ralf Corsepius | 1 | -0/+4 | |
2003-02-11 | 2003-02-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+4 | |
* configure.ac: AM_INIT_AUTOMAKE([1.7.2]). | |||||
* configure.ac: AC_PREREQ(2.57). | |||||
2002-10-21 | 2002-10-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+6 | |
* .cvsignore: Reformat. Add autom4te*cache. Remove autom4te.cache. | |||||
2002-04-03 | 2002-04-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1 | -0/+4 | |
* configure.ac: Remove AC_EXEEXT (obsolete). | |||||
2002-03-28 | 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1 | -0/+7 | |
* configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * Makefile.am: Remove AUTOMAKE_OPTIONS. | |||||
2001-10-11 | 2001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1 | -0/+6 | |
* .cvsignore: Add autom4te.cache for autoconf > 2.52. * configure.in: Remove. * configure.ac: New file, generated from configure.in by autoupdate. | |||||
2001-02-02 | 2001-02-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1 | -0/+4 | |
* .cvsignore: Add stamp-h | |||||
2001-01-24 | 2001-01-24 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1 | -0/+4 | |
* config.h.in: Automatically generated. Remove from CVS. | |||||
2000-11-09 | 2000-11-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1 | -0/+4 | |
* Makefile.am: Use ... instead of RTEMS_TOPdir in ACLOCAL_AMFLAGS. | |||||
2000-11-02 | 2000-11-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1 | -0/+4 | |
* Makefile.am: Switch to ACLOCAL_AMFLAGS = -I $(RTEMS_TOPdir)/aclocal. | |||||
2000-10-27 | 2000-10-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1 | -1/+1 | |
* Makefile.am: ACLOCAL_AMFLAGS= -I $(RTEMS_TOPdir)/macros. Switch to GNU canonicalization. | |||||
2000-10-27 | 2000-10-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1 | -0/+5 | |
* configure.in, Makefile.am: ACLOCAL_AMFLAGS= -I $(RTEMS_TOPdir)/macros. Switch to GNU canonicalization. | |||||
2000-08-10 | Adding ChangeLogs. | Joel Sherrill | 1 | -0/+3 | |
