* hppa1.1/.cvsignore, hppa1.1/ChangeLog, hppa1.1/Makefile.am,
hppa1.1/acinclude.m4, hppa1.1/configure.ac,
hppa1.1/simhppa/.cvsignore, hppa1.1/simhppa/ChangeLog,
hppa1.1/simhppa/Makefile.am, hppa1.1/simhppa/bsp_specs,
hppa1.1/simhppa/configure.ac, hppa1.1/simhppa/times,
hppa1.1/simhppa/include/.cvsignore,
hppa1.1/simhppa/include/Makefile.am, hppa1.1/simhppa/include/bsp.h,
hppa1.1/simhppa/include/ttydrv.h, hppa1.1/simhppa/shmsupp/.cvsignore,
hppa1.1/simhppa/shmsupp/Makefile.am, hppa1.1/simhppa/shmsupp/README,
hppa1.1/simhppa/shmsupp/addrconv.c,
hppa1.1/simhppa/shmsupp/cause_intr.c,
hppa1.1/simhppa/shmsupp/getcfg.c, hppa1.1/simhppa/shmsupp/lock.c,
hppa1.1/simhppa/shmsupp/mpisr.c, hppa1.1/simhppa/start/.cvsignore,
hppa1.1/simhppa/start/Makefile.am, hppa1.1/simhppa/start/start.S,
hppa1.1/simhppa/startup/.cvsignore,
hppa1.1/simhppa/startup/Makefile.am,
hppa1.1/simhppa/startup/bspclean.c,
hppa1.1/simhppa/startup/bspstart.c, hppa1.1/simhppa/startup/linkcmds,
hppa1.1/simhppa/startup/setvec.c, hppa1.1/simhppa/tools/.cvsignore,
hppa1.1/simhppa/tools/ChangeLog, hppa1.1/simhppa/tools/Makefile.am,
hppa1.1/simhppa/tools/configure.ac,
hppa1.1/simhppa/tools/print_dump.c, hppa1.1/simhppa/tty/.cvsignore,
hppa1.1/simhppa/tty/Makefile.am, hppa1.1/simhppa/tty/tty.c,
hppa1.1/simhppa/wrapup/.cvsignore,
hppa1.1/simhppa/wrapup/Makefile.am: Removed.
be resolved.
