path: root/c/src/lib/libbsp/h8300/h8sim (follow)
* h8sim/bsp_specs: Add crtbegin/end, crt[in]Joel Sherrill2014-04-221-1/+4
* bsps: Fix TLS support in linker command filesSebastian Huber2014-04-221-1/+3
| | | | | The TLS section symbols had wrong values in case of an empty TLS data section and a nonempty TLS BSS section.
* h8sim/console/console-io.c: Comment clean upJoel Sherrill2014-04-031-1/+3
* h8sim/include/bsp.h: Remove rtems_bsp_delay()Joel Sherrill2014-03-211-16/+0
* Change all references of rtems.com to rtems.org.Chris Johns2014-03-213-3/+3
* bsps: Add empty cache managerSebastian Huber2014-02-241-0/+5
| | | | | This is necessary to add tests that use the cache manager. For example to get better estimates of worst-case timings.
* bsps: Thread-local storage (TLS) for linkcmdsSebastian Huber2014-02-041-1/+15
* libbsp misc: Fix comment formattingJoel Sherrill2013-12-301-18/+15
* h8sim: Add Doxygen directivesSzkocsovszki Zsolt2013-12-282-1/+31
* RTEMS: Delete ChangeLog files.Gedare Bloom2013-03-081-591/+0
| | | | | | | | | This commit deletes all RTEMS ChangeLog files. These files have been abandoned since converting to git version control. The historical data may be recovered by checking out any commit before this one. Most of the contents of these ChangeLog files can also be found in the git log. Two external ChangeLog files, ChangeLog.slac and ChangeLog.zlib, remain.
* score: Add RTEMS_FATAL_SOURCE_EXITSebastian Huber2012-11-151-0/+1
| | | | | | | Include <bsp/default-initial-extension.h> in all BSPs. Call rtems_fatal() with RTEMS_FATAL_SOURCE_EXIT as source and the exit() status code as fatal code in every bsp_cleanup(). Move previous bsp_cleanup() code into bsp_fatal_extension().
* Revert "Add bspopts.h.in."Gedare Bloom2012-08-061-31/+0
| | | | | | | | | | | | This reverts commit daffa606cc4a45d93c1f0f4fe365fde0fda6acbb. Conflicts: c/src/lib/libbsp/arm/lpc24xx/include/bspopts.h.in c/src/lib/libbsp/powerpc/mpc55xxevb/include/bspopts.h.in c/src/lib/libbsp/powerpc/qoriq/include/bspopts.h.in Manually deleted conflicting files.
* Require automake-1.12.2.Ralf Corsépius2012-07-191-1/+1
* Require autoconf-2.69.Ralf Corsépius2012-07-191-1/+1
* Add bspopts.h.in.Ralf Corsépius2012-05-241-0/+31
* Remove All CVS Id Strings Possible Using a ScriptJoel Sherrill2012-05-118-18/+0
* Remove CVS-Ids.Ralf Corsépius2012-05-042-6/+0
* Remove all .cvsignore files.Joel Sherrill2012-02-012-13/+0
* 2011-06-20 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-06-202-2/+4
| | | | * Makefile.am: Don't reference non-existing files.
* 2011-02-11 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-02-112-1/+6
| | | | | * include/bsp.h: Use "__asm__" instead of "asm" for improved c99-compliance.
* 2011-02-02 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-02-022-2/+6
| | | | * configure.ac: Require autoconf-2.68, automake-1.11.1.
* Whitespace removal.Ralf Corsepius2009-11-281-1/+1
* 2009-11-09 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2009-11-092-5/+5
| | | | * start/start.S: Remove warning.
* 2009-10-21 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2009-10-213-6/+5
| | | | | * make/custom/h8sim.cfg: Remove RTEMS_BSP_FAMILY. * make/custom/h8sxsim.cfg: Remove RTEMS_BSP_FAMILY.
* 2009-10-20 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2009-10-202-1/+5
| | | | * configure.ac: Don't add -ansi -fasm to CFLAGS.
* 2009-10-15 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2009-10-153-0/+47
| | | | | * make/custom/h8sim.cfg: New (relocated from /make/custom). * make/custom/h8sxsim.cfg: New (relocated from /make/custom).
* 2009-09-15 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2009-09-152-2/+5
| | | | * configure.ac: Remove RTEMS_BSP_BOOTCARD_OPTIONS.
* 2009-07-16 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2009-07-162-1/+8
| | | | | | * configure.ac: Rename BSP_BOOTCARD_OPTIONS to RTEMS_BSP_BOOTCARD_OPTIONS. Add RTEMS_BSP_CLEANUP_OPTIONS so all BSPs have the same options.
* 2009-04-28 Chris Johns <chrisj@rtems.org>Chris Johns2009-04-282-0/+9
| | | | * start/start.S: Update for boot_card command line change.
* 2008-12-04 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-12-042-2/+8
| | | | | | * bsp_specs: Move -e start from *link to *startfile to avoid warning for undefined entry symbol when linking relocatables with binutils 2.19.
* 2008-10-14 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-10-142-1/+5
| | | | | * startup/linkcmds: Do not specify architecture since the linker gets it right even with multiple variants.
* 2008-10-02 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2008-10-024-34/+7
| | | | | * Makefile.am, preinstall.am: Use shared tm27.h stub. * include/tm27.h: Removed.
* 2008-09-29 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2008-09-292-6/+9
| | | | | * Makefile.am: Eliminate bsp.am. Build startup files as side-effect of building libbspstart.a, using automake-rules.
* 2008-09-29 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2008-09-292-7/+13
| | | | * Makefile.am: Eliminate *_SOURCES.
* 2008-09-29 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2008-09-292-1/+7
| | | | | * Makefile.am: Move noinst_LIBRARIES = libbsp.a before its components.
* 2008-09-29 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2008-09-292-1/+4
| | | | * Makefile.am: Remove noinst_PROGRAMS (Unused).
* 2008-09-26 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2008-09-263-0/+16
| | | | * Makefile.am: Cleanup ../../shared/include/bootcard.h handling.
* 2008-09-25 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-09-253-9/+54
| | | | | * console/console-io.c: Add missing file and remove junk code. * console/syscalls.S: New file.
* 2008-09-24 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-09-242-4/+9
| | | | | * startup/linkcmds: Simulator now appears to have 16M RAM support by default in gdb 6.8.
* 2008-09-24 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-09-244-5/+21
| | | | * Makefile.am, console/console-io.c, include/bsp.h:
* 2008-09-23 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-09-232-1/+7
| | | | | | * configure.ac: Make letting boot_card() handle work area allocation mandatory. Rename RTEMS_BSP_BOOTCARD_HANDLES_RAM_ALLOCATION to BSP_BOOTCARD_OPTIONS.
* 2008-09-19 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-09-194-37/+28
| | | | | | | * Makefile.am: Split out bspstart contents. Use shared stub for bsp_start. * startup/h8bdinstallirq.c: New file. * startup/bspstart.c: Removed.
* 2008-09-18 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-09-182-16/+4
| | | | * include/bsp.h: Remove unnecessary boilerplate comments.
* 2008-09-16 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-09-164-36/+10
| | | | | | * Makefile.am, startup/linkcmds: Use top level shared bsp_get_work_area() implementation. * startup/bspgetworkarea.c: Removed.
* 2008-09-16 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-09-162-2/+5
| | | | | * startup/bspstart.c: Remove unnecessary includes of rtems/libcsupport.h and rtems/libio.h.
* 2008-09-14 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-09-146-55/+56
| | | | | | | * Makefile.am, configure.ac, startup/__main.c, startup/bspstart.c: Split out bsp_get_work_area() into its own file and user BSP Framework to perform more initialization. * startup/bspgetworkarea.c: New file.
* 2008-09-10 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-09-102-4/+6
| | | | | | * include/bsp.h: Review of all bsp_cleanup() implementations. In this phase, all prototypes were removed from bsp.h and empty implementations were removed and made to use the shared stub.
* 2008-08-19 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2008-08-191-0/+4
| | | | * startup/__main.c: Add missing prototypes.
* Add missing prototypes.Ralf Corsepius2008-08-191-2/+2
* Cleanup.Ralf Corsepius2008-07-141-6/+0
