2015-12-13 | h8300/h8sim: Remove | Aun-Ali Zaidi | 1 | -123/+0 | |
updates #2453. | |||||
2015-12-08 | Add RTEMS linker sets | Sebastian Huber | 1 | -0/+2 | |
Update #2408. | |||||
2014-04-29 | bsp/h8sim: Fix linker command file | Sebastian Huber | 1 | -0/+2 | |
2014-04-22 | bsps: Fix TLS support in linker command files | Sebastian Huber | 1 | -1/+3 | |
The TLS section symbols had wrong values in case of an empty TLS data section and a nonempty TLS BSS section. | |||||
2014-02-04 | bsps: Thread-local storage (TLS) for linkcmds | Sebastian Huber | 1 | -1/+15 | |
2012-05-11 | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 1 | -4/+0 | |
Script does what is expected and tries to do it as smartly as possible. + remove occurrences of two blank comment lines next to each other after Id string line removed. + remove entire comment blocks which only exited to contain CVS Ids + If the processing left a blank line at the top of a file, it was removed. | |||||
2008-10-14 | 2008-10-14 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 1 | -1/+0 | |
* startup/linkcmds: Do not specify architecture since the linker gets it right even with multiple variants. | |||||
2008-09-24 | 2008-09-24 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 1 | -4/+4 | |
* startup/linkcmds: Simulator now appears to have 16M RAM support by default in gdb 6.8. | |||||
2008-09-16 | 2008-09-16 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 1 | -3/+3 | |
* Makefile.am, startup/linkcmds: Use top level shared bsp_get_work_area() implementation. * startup/bspgetworkarea.c: Removed. | |||||
2007-05-03 | 2007-05-03 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -1/+1 | |
* startup/linkcmds: Handle .data.* sections | |||||
2006-02-08 | 2006-02-08 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -11/+12 | |
* startup/linkcmds: Add sections required by newer gcc versions. | |||||
2005-05-11 | 2005-05-11 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -1/+1 | |
* startup/linkcmds: Add .rodata.* sections. | |||||
2005-03-07 | 2005-03-07 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -7/+7 | |
* startup/linkcmds: Hacked so there is enough memory to link pppd.exe. | |||||
2003-01-20 | 2003-01-20 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -0/+10 | |
* startup/linkcmds: Add FreeBSD SYSCTL() sections for networking. | |||||
2002-08-05 | 2002-08-05 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -5/+3 | |
* startup/bspstart.c, startup/linkcmds: Per PR247 , fix the linkcmds to avoid overlapping sections and reworked the way the heap and workspace are calculated. | |||||
2000-07-31 | Closer to linking. h8300-rtems-ld now core dumps. | Joel Sherrill | 1 | -16/+21 | |
2000-07-06 | Added baseline for h8 simulator BSP to support the simulator in gdb 5.0 | Joel Sherrill | 1 | -5/+44 | |
2000-06-12 | Added i960sim BSP which (ignoring the 3 instructions not supported | Joel Sherrill | 1 | -0/+55 | |
by gdb 5.0's i960 simulator) is enough to run hello world. |
