* Makefile.am, configure.ac, startup/__main.c, startup/bspstart.c:
Split out bsp_get_work_area() into its own file and user BSP
Framework to perform more initialization.
* startup/bspgetworkarea.c: New file.
start/Makefile.am, startup/Makefile.am, wrapup/Makefile.am.
startup/Makefile.am, wrapup/Makefile.am: Remove.
Use automake compilation rules.
Reflect changes to bsp.am.
* configure.in: Remove.
