start/Makefile.am, startup/Makefile.am, wrapup/Makefile.am.
startup/Makefile.am, wrapup/Makefile.am: Remove.
Use automake compilation rules.
* clock/Makefile.am: Misc cleanups and fixes.
* Makefile.am: Add dirstamps to preinstallation.
* configure.in, Makefile.am, clock/Makefile.am, clock/.cvsignore,
wrapup/Makefile.am: Added include of stub clock driver so ticker
would link.
