* include/bsp.h: New header guard.
* startup/linkcmds: Add .rodata.* sections.
* Makefile.am: Add timerstub so more tests link.
* startup/linkcmds: Hacked so there is enough memory to link pppd.exe.
* Makefile.am: Eliminate CFLAGS_OPTIMIZE_V.
* Makefile.am: Remove build-variant support.
* include/bsp.h, include/tm27.h: i960 obsoleted and all references
removed.
PR 610/bsps
* Makefile.am: Add include/tm27.h, Cosmetics.
* include/tm27.h: Final cosmetics.
* include/tm27.h: New.
PR 613/bsps
PR 614/bsps
* include/bsp.h, startup/bspstart.c: Convert to using c99 fixed size
types.
* Makefile.am: Reflect changes to bsp.am.
Preinstall dist_project_lib*.
* Makefile.am: Use CPPASCOMPILE instead of CCASCOMPILE.
start/Makefile.am, startup/Makefile.am, wrapup/Makefile.am.
startup/Makefile.am, wrapup/Makefile.am: Remove.
Use automake compilation rules.
* start/Makefile.am: Re-add dirstamps to PRE/TMPINSTALL_FILES.
* startup/Makefile.am: Ditto.
* wrapup/Makefile.am: Eliminate $(LIB).
Use noinst_DATA to trigger building libbsp.a.
* clock/Makefile.am: Misc cleanups and fixes.
* Makefile.am: Add dirstamps to preinstallation.
* bsp_specs: Remove *lib:.
* console/console-io.c, include/bsp.h, startup/bspstart.c: URL for
license changed.
* startup/linkcmds: Add FreeBSD SYSCTL() sections for networking.
* startup/bspstart.c: Add empty H8BD_Install_IRQ so the port will have
a routine to call.
* startup/bspstart.c: Remove ramStart to eliminate warning.
* .cvsignore: Reformat.
Add autom4te*cache.
Remove autom4te.cache.
* startup/bspstart.c, startup/linkcmds: Per PR247 , fix the linkcmds
to avoid overlapping sections and reworked the way the heap and
workspace are calculated.
