* configure.in: Add bspopts.h, fix PACKAGE.
* console/consolereserveresources.c: Removed code NOT file (YET).
* configure.in, Makefile.am: ACLOCAL_AMFLAGS= -I $(RTEMS_TOPdir)/macros.
* startup/linkcmds: Use default object format to avoid name
changes in object format due to tool version changes.
* Makefile.am: Formatting.
startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am:
Include compile.am
linkcmds updated, simio references removed, and switch to libchip for
serial ports from simio.
Added a MEMORY_MAP file to capture information about the various
addresses on this board.
In addition, many of the beta patches are now included.
