* | 2006-05-31 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-05-31 | 2 | -172/+11 |
| | | | | * clock/clock.c: Switch to using shared clock driver shell. | ||||
* | Remove eof include file | Ralf Corsepius | 2006-03-17 | 1 | -1/+0 |
* | Regenerate. | Ralf Corsepius | 2006-01-14 | 1 | -1/+1 |
* | Regenerate. | Ralf Corsepius | 2006-01-12 | 1 | -0/+4 |
* | Remove all-local:. | Ralf Corsepius | 2006-01-12 | 1 | -2/+0 |
* | Regenerate. | Ralf Corsepius | 2006-01-12 | 1 | -1/+1 |
* | Cleanup. | Ralf Corsepius | 2006-01-12 | 1 | -1/+0 |
* | New. | Ralf Corsepius | 2006-01-11 | 1 | -0/+58 |
* | 2006-01-11 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-01-11 | 2 | -50/+6 |
| | | | | * Makefile.am: Add preinstall.am. | ||||
* | 2005-10-16 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-10-16 | 1 | -22/+34 |
| | | | | | | * Makefile.am: Merge-in shared/Makefile.am. * ChangeLog: Merge-in shared/ChangeLog. * configure.ac: Remove shared/Makefile.am. | ||||
* | Remove shared/Makefile.am. | Ralf Corsepius | 2005-10-16 | 1 | -2/+1 |
* | Merge-in shared/Makefile.am. | Ralf Corsepius | 2005-10-16 | 1 | -1/+6 |
* | Remove. | Ralf Corsepius | 2005-10-16 | 3 | -45/+0 |
* | 2005-05-26 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-05-26 | 2 | -2/+6 |
| | | | | * include/bsp.h: New header guard. | ||||
* | 2005-02-02 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-02-02 | 3 | -2/+7 |
| | | | | | * include/tm27.h, timer/timer.c: #include <rtems/tic4x/c4xio.h> instead of <rtems/tic4x/c4xio.h>. | ||||
* | 2005-01-07 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-01-07 | 2 | -4/+8 |
| | | | | * Makefile.am: Eliminate CFLAGS_OPTIMIZE_V. | ||||
* | 2005-01-02 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-01-03 | 2 | -61/+20 |
| | | | | * Makefile.am: Remove build-variant support. | ||||
* | Fix typo in previous change. | Ralf Corsepius | 2004-09-24 | 3 | -3/+3 |
* | 2004-09-24 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-09-24 | 6 | -3/+15 |
| | | | | * configure.ac: Require automake > 1.9. | ||||
* | 2004-04-23 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-04-23 | 3 | -3/+12 |
| | | | | | | PR 610/bsps * Makefile.am: Add include/tm27.h, Cosmetics. * include/tm27.h: Final cosmetics. | ||||
* | 2004-04-22 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-04-22 | 3 | -26/+51 |
| | | | | | * include/bsp.h: Split out tmtest27 support. * include/tm27.h: New. | ||||
* | 2004-04-21 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-04-21 | 2 | -10/+5 |
| | | | | | PR 613/bsps * include/bsp.h: Remove MAX_LONG_TEST_DURATION. | ||||
* | 2004-04-21 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-04-21 | 2 | -1/+5 |
| | | | | | PR 614/bsps * include/bsp.h: Remove MAX_SHORT_TEST_DURATION (Unused). | ||||
* | Remove duplicate white lines. | Ralf Corsepius | 2004-04-21 | 4 | -6/+0 |
* | Remove stray white spaces. | Ralf Corsepius | 2004-04-21 | 11 | -32/+32 |
* | Remove stray white spaces. | Ralf Corsepius | 2004-04-15 | 2 | -2/+0 |
* | 2004-04-02 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-04-02 | 4 | -3/+8 |
| | | | | | * clock/clock.c, include/bsp.h, timer/timer.c: Include <rtems/c4x/c4xio.h> instead of <c4xio.h>. | ||||
* | 2004-04-01 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-04-01 | 2 | -4/+10 |
| | | | | | | * include/bsp.h: Include <rtems/clockdrv.h> instead of <clockdrv.h>. * include/bsp.h: Include <rtems/console.h> instead of <console.h>. * include/bsp.h: Include <rtems/iosupp.h> instead of <iosupp.h>. | ||||
* | 2004-03-31 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-03-31 | 2 | -1/+5 |
| | | | | * bspspuriousinit.c: Convert to using c99 fixed size types. | ||||
* | 2004-03-31 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-03-31 | 5 | -12/+17 |
| | | | | | * clock/clock.c, include/bsp.h, startup/bspstart.c, timer/timer.c: Convert to using c99 fixed size types. | ||||
* | Remove refs to Makefile*. | Ralf Corsepius | 2004-03-09 | 1 | -2/+0 |
* | 2004-02-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-02-19 | 2 | -2/+35 |
| | | | | | * Makefile.am: Reflect changes to bsp.am. Preinstall dist_project_lib*. | ||||
* | 2004-02-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-02-14 | 2 | -1/+9 |
| | | | | * Makefile.am: Reflect changes to bsp.am. | ||||
* | 2004-02-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-02-12 | 2 | -2/+6 |
| | | | | * acinclude.m4: Regenerate. | ||||
* | 2004-02-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-02-12 | 2 | -1/+5 |
| | | | | * configure.ac: RTEMS_CHECK_BSPDIR([$RTEMS_BSP_FAMILY]). | ||||
| | | | | * Makefile.am: Use CPPASCOMPILE instead of CCASCOMPILE. | ||||
* | 2004-02-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-02-06 | 2 | -2/+7 |
| | | | | | * Makefile.am: Pickup files from ../../c4x/shared instead of ../shared. Reformat. | ||||
* | Remove unnecessary .cvsignore | Ralf Corsepius | 2004-01-29 | 6 | -12/+0 |
* | 2004-01-29 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-01-29 | 9 | -210/+115 |
| | | | | | | | | | | | * Makefile.am: Merge-in clock/Makefile.am, console/Makefile.am, start/Makefile.am, startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am. Use automake compilation rules. * clock/Makefile.am, console/Makefile.am, start/Makefile.am, startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am: Remove. * configure.ac: Reflect changes above. | ||||
* | 2004-01-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-01-29 | 2 | -1/+7 |
| | | | | | * configure.ac: Add nostdinc to AUTOMAKE_OPTIONS. Add RTEMS_PROG_CCAS. | ||||
* | 2004-01-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-01-21 | 2 | -0/+7 |
| | | | | * Makefile.am: Add PREINSTALL_DIRS. | ||||
* | 2004-01-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-01-14 | 4 | -0/+19 |
| | | | | | | | * Makefile.am: Re-add dirstamps to PRE/TMPINSTALL_FILES. Add PRE/TMPINSTALL_FILES to CLEANFILES. * start/Makefile.am: Ditto. * startup/Makefile.am: Ditto. | ||||
* | 2004-01-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-01-14 | 2 | -0/+8 |
| | | | | | * Makefile.am: Re-add dirstamps to PRE/TMPINSTALL_FILES. Add PRE/TMPINSTALL_FILES to CLEANFILES. | ||||
* | 2004-01-13 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-01-13 | 2 | -2/+7 |
| | | | | | * Makefile.am: Use @RTEMS_BSP_FAMILY@ instead of $(RTEMS_BSP_FAMILY). | ||||
* | 2004-01-05 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-01-05 | 2 | -7/+7 |
| | | | | | * wrapup/Makefile.am: Eliminate $(LIB). Use noinst_DATA to trigger building libbsp.a. | ||||
* | 2003-12-13 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-13 | 3 | -12/+17 |
| | | | | | * start/Makefile.am: s,${PROJECT_RELEASE}/lib,$(PROJECT_LIB),g. * startup/Makefile.am: s,${PROJECT_RELEASE}/lib,$(PROJECT_LIB),g. | ||||
* | 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-12 | 3 | -0/+13 |
| | | | | | * start/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES. * startup/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES. | ||||
* | 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-12 | 2 | -5/+18 |
| | | | | * Makefile.am: Reworked. | ||||
* | 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-12 | 6 | -6/+18 |
| | | | | * configure.ac: Require automake >= 1.8, autoconf >= 2.59. | ||||
* | 2003-12-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-09 | 4 | -22/+21 |
| | | | | | | * start/Makefile.am: Misc cleanups and fixes. * startup/Makefile.am: Misc cleanups and fixes. * wrapup/Makefile.am: Misc cleanups and fixes. |
