* clock/clock.c: Per PR257, remove reference to c3x_set_ie.
c4x variant should use c4x_set_iie().
* shared/bspspuriousinit.c: Include rtems/bspIo.h instead of bspIo.h.
* shared/c3xspurious.c: Include rtems/bspIo.h instead of bspIo.h.
* shared/c4xspurious.c: Include rtems/bspIo.h instead of bspIo.h.
* startup/bspstart.c: Include rtems/bspIo.h instead of bspIo.h.
* startup/spurious.c: Include rtems/bspIo.h instead of bspIo.h.
* console/console.c: Fixed typo.
* configure.in: Remove.
* acinclude.m4: New file.
* configure.in: Add bspopts.h, fix PACKAGE.
* console/consolereserveresources.c: Removed code NOT file (YET).
* configure.in, Makefile.am: ACLOCAL_AMFLAGS= -I $(RTEMS_TOPdir)/macros.
* startup/linkcmds: Use default object format to avoid name
changes in object format due to tool version changes.
* Makefile.am: Formatting.
startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am:
Include compile.am
linkcmds updated, simio references removed, and switch to libchip for
serial ports from simio.
Added a MEMORY_MAP file to capture information about the various
addresses on this board.
In addition, many of the beta patches are now included.
