* bspspuriousinit.c, c3xspurious.c, c4xspurious.c: URL for license
changed.
* clock/clock.c, console/console.c, console/consolereserveresources.c,
console/debugio.c, include/bsp.h, startup/bspstart.c,
startup/spurious.c, timer/timer.c: URL for license changed.
PR 445/bsps
* bsp_specs: Hand edited to duplicate change Ralf applied to the CVS
trunk.
* runtest.in: Add fileio to list of interactive tests.
* configure.ac: Remove AC_CONFIG_AUX_DIR.
* startup/linkcmds: Add FreeBSD SYSCTL() sections for networking.
* configure.ac: Remove RTEMS_OUTPUT_BUILD_SUBDIRS. Cosmetical
changes.
* .cvsignore: Reformat.
Add autom4te*cache.
Remove autom4te.cache.
* clock/clock.c: Per PR257, remove reference to c3x_set_ie.
c4x variant should use c4x_set_iie().
* shared/bspspuriousinit.c: Include rtems/bspIo.h instead of bspIo.h.
* shared/c3xspurious.c: Include rtems/bspIo.h instead of bspIo.h.
* shared/c4xspurious.c: Include rtems/bspIo.h instead of bspIo.h.
* startup/bspstart.c: Include rtems/bspIo.h instead of bspIo.h.
* startup/spurious.c: Include rtems/bspIo.h instead of bspIo.h.
* console/console.c: Fixed typo.
* configure.in: Remove.
* acinclude.m4: New file.
* configure.in: Add bspopts.h, fix PACKAGE.
* console/consolereserveresources.c: Removed code NOT file (YET).
* configure.in, Makefile.am: ACLOCAL_AMFLAGS= -I $(RTEMS_TOPdir)/macros.
* startup/linkcmds: Use default object format to avoid name
changes in object format due to tool version changes.
* Makefile.am: Formatting.
startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am:
Include compile.am
