* Makefile.am: Reworked.
* runtest.in: Add fileio to list of interactive tests.
* .cvsignore: Reformat.
Add autom4te*cache.
Remove autom4te.cache.
* configure.in: Remove.
startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am:
Include compile.am
