path: root/c/src/lib/libbsp/c4x/c4xsim/timer (unfollow)
2010-06-11Remove (Abandoned).Ralf Corsepius1-105/+0
2008-09-05Convert to "bool".Ralf Corsepius1-3/+3
2008-08-312008-08-31 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill1-19/+9
* timer/timer.c: Eliminate empty function from every benchmark timer driver. Fix spelling.
2008-08-312008-08-31 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill1-10/+10
* timer/timer.c: Rename timer driver methods to follow RTEMS programming conventions.
2005-02-022005-02-02 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius1-1/+1
* include/tm27.h, timer/timer.c: #include <rtems/tic4x/c4xio.h> instead of <rtems/tic4x/c4xio.h>.
2004-04-21Remove duplicate white lines.Ralf Corsepius1-1/+0
2004-04-21Remove stray white spaces.Ralf Corsepius1-1/+1
2004-04-15Remove stray white spaces.Ralf Corsepius1-1/+0
2004-04-022004-04-02 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius1-1/+1
* clock/clock.c, include/bsp.h, timer/timer.c: Include <rtems/c4x/c4xio.h> instead of <c4xio.h>.
2004-03-312004-03-31 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius1-4/+4
* clock/clock.c, include/bsp.h, startup/bspstart.c, timer/timer.c: Convert to using c99 fixed size types.
2004-01-29Remove unnecessary .cvsignoreRalf Corsepius1-2/+0
2004-01-292004-01-29 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius1-30/+0
* Makefile.am: Merge-in clock/Makefile.am, console/Makefile.am, start/Makefile.am, startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am. Use automake compilation rules. * clock/Makefile.am, console/Makefile.am, start/Makefile.am, startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am: Remove. * configure.ac: Reflect changes above.
2003-12-032003-12-03 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius1-1/+0
* Makefile.am: Add preinstallation dirstamp support. * clock/Makefile.am: Cosmetics. * console/Makefile.am: Cosmetics. * startup/Makefile.am: Cosmetics. * timer/Makefile.am: Cosmetics. * wrapup/Makefile.am: Cosmetics.
2003-12-022003-12-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius1-1/+1
* clock/Makefile.am: Remove all-local: $(ARCH). * console/Makefile.am: Remove all-local: $(ARCH). * start/Makefile.am: Remove all-local: $(ARCH). * startup/Makefile.am: Remove all-local: $(ARCH). * timer/Makefile.am: Remove all-local: $(ARCH). * wrapup/Makefile.am: Remove all-local: $(ARCH).
2003-09-042003-09-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill1-1/+1
* clock/clock.c, console/console.c, console/consolereserveresources.c, console/debugio.c, include/bsp.h, startup/bspstart.c, startup/spurious.c, timer/timer.c: URL for license changed.
2003-08-162003-08-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius1-3/+3
Makefile.am: Reflect having moved automake. clock/Makefile.am: Reflect having moved automake. console/Makefile.am: Reflect having moved automake. include/Makefile.am: Reflect having moved automake. start/Makefile.am: Reflect having moved automake. startup/Makefile.am: Reflect having moved automake. timer/Makefile.am: Reflect having moved automake. wrapup/Makefile.am: Reflect having moved automake.
2002-12-192002-12-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius1-1/+0
* clock/Makefile.am: Don't include @RTEMS_BSP@.cfg. * console/Makefile.am: Don't include @RTEMS_BSP@.cfg. * start/Makefile.am: Don't include @RTEMS_BSP@.cfg. * startup/Makefile.am: Don't include @RTEMS_BSP@.cfg. * timer/Makefile.am: Don't include @RTEMS_BSP@.cfg.
2002-08-112002-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius1-1/+1
* clock/Makefile.am: Use .$(OBJEXT) instead of .o. * console/Makefile.am: Use .$(OBJEXT) instead of .o. * start/Makefile.am: Use .$(OBJEXT) instead of .o. * startup/Makefile.am: Use .$(OBJEXT) instead of .o. * timer/Makefile.am: Use .$(OBJEXT) instead of .o. * wrapup/Makefile.am: Use .$(OBJEXT) instead of .o.
2002-03-282002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-1/+0
* configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * clock/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. * console/Makefile.am: Remove AUTOMAKE_OPTIONS. * include/Makefile.am: Remove AUTOMAKE_OPTIONS. * start/Makefile.am: Remove AUTOMAKE_OPTIONS. * startup/Makefile.am: Remove AUTOMAKE_OPTIONS. * timer/Makefile.am: Remove AUTOMAKE_OPTIONS. * wrapup/Makefile.am: Remove AUTOMAKE_OPTIONS.
2000-09-052000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-2/+3
* clock/Makefile.am, console/Makefile.am, start/Makefile.am, startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am: Include compile.am
2000-07-26Port of RTEMS to the Texas Instruments C3x/C4x DSP families includingJoel Sherrill1-0/+2
a BSP (c4xsim) supporting the simulator included with gdb. This port was done by Joel Sherrill and Jennifer Averett of OAR Corporation. Also included with this port is a space/time optimization to eliminate FP context switch management on CPUs without hardware or software FP. An issue with this port was that sizeof(unsigned32) = sizeof(unsigned8) on this CPU. This required addressing alignment checks and assumptions as well as fixing code that assumed sizeof(unsigned32) == 4.
2000-02-22New port of RTEMS to TI C3x and C4x.Joel Sherrill2-0/+149
