path: root/c/src/lib/libbsp/c4x/c4xsim/timer (follow)
* 2000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-051-2/+3
| | | | | | * clock/Makefile.am, console/Makefile.am, start/Makefile.am, startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am: Include compile.am
* Port of RTEMS to the Texas Instruments C3x/C4x DSP families includingJoel Sherrill2000-07-261-0/+2
| | | | | | | | | | | a BSP (c4xsim) supporting the simulator included with gdb. This port was done by Joel Sherrill and Jennifer Averett of OAR Corporation. Also included with this port is a space/time optimization to eliminate FP context switch management on CPUs without hardware or software FP. An issue with this port was that sizeof(unsigned32) = sizeof(unsigned8) on this CPU. This required addressing alignment checks and assumptions as well as fixing code that assumed sizeof(unsigned32) == 4.
* New port of RTEMS to TI C3x and C4x.Joel Sherrill2000-02-222-0/+149
