wrapup/Makefile.am.
Use automake compilation rules.
startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am:
Remove.
* start/Makefile.am: Ditto.
* startup/Makefile.am: Ditto.
Include compile.am
