2000-09-05 | 2000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1 | -2/+3 | |
* clock/Makefile.am, console/Makefile.am, start/Makefile.am, startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am: Include compile.am | |||||
2000-07-26 | Port of RTEMS to the Texas Instruments C3x/C4x DSP families including | Joel Sherrill | 1 | -0/+2 | |
a BSP (c4xsim) supporting the simulator included with gdb. This port was done by Joel Sherrill and Jennifer Averett of OAR Corporation. Also included with this port is a space/time optimization to eliminate FP context switch management on CPUs without hardware or software FP. An issue with this port was that sizeof(unsigned32) = sizeof(unsigned8) on this CPU. This required addressing alignment checks and assumptions as well as fixing code that assumed sizeof(unsigned32) == 4. | |||||
2000-02-22 | New port of RTEMS to TI C3x and C4x. | Joel Sherrill | 2 | -0/+103 | |
