startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am:
Include compile.am
linkcmds updated, simio references removed, and switch to libchip for
serial ports from simio.
Added a MEMORY_MAP file to capture information about the various
addresses on this board.
In addition, many of the beta patches are now included.
