* clock/clock.c, include/bsp.h, startup/bspstart.c: Eliminate copies of
the Configuration Table. Use the RTEMS provided accessor macros to
obtain configuration fields.
* clock/clock.c: include <tic4x/c4xio.h>.
* clock/clock.c: Switch to using shared clock driver shell.
* clock/clock.c, include/bsp.h, timer/timer.c: Include
<rtems/c4x/c4xio.h> instead of <c4xio.h>.
* clock/clock.c, include/bsp.h, startup/bspstart.c, timer/timer.c:
Convert to using c99 fixed size types.
wrapup/Makefile.am.
Use automake compilation rules.
startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am:
Remove.
* clock/clock.c, console/console.c, console/consolereserveresources.c,
console/debugio.c, include/bsp.h, startup/bspstart.c,
startup/spurious.c, timer/timer.c: URL for license changed.
* clock/clock.c: Per PR257, remove reference to c3x_set_ie.
c4x variant should use c4x_set_iie().
Include compile.am
