* configure.in, Makefile.am: ACLOCAL_AMFLAGS= -I $(RTEMS_TOPdir)/macros.
* startup/linkcmds: Use default object format to avoid name
changes in object format due to tool version changes.
startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am:
Include compile.am
