path: root/c/src/lib/libbsp/c4x/c4xsim/.cvsignore (unfollow)
2000-07-26Port of RTEMS to the Texas Instruments C3x/C4x DSP families includingJoel Sherrill1-0/+0
a BSP (c4xsim) supporting the simulator included with gdb. This port was done by Joel Sherrill and Jennifer Averett of OAR Corporation. Also included with this port is a space/time optimization to eliminate FP context switch management on CPUs without hardware or software FP. An issue with this port was that sizeof(unsigned32) = sizeof(unsigned8) on this CPU. This required addressing alignment checks and assumptions as well as fixing code that assumed sizeof(unsigned32) == 4.
2000-04-13Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>.Joel Sherrill1-0/+13
