path: root/c/src/lib/libbsp/bsp.am (follow)
* Remove All CVS Id Strings Possible Using a ScriptJoel Sherrill2012-05-111-4/+0
* Remove stray white spaces.Ralf Corsepius2004-04-211-2/+2
* 2004-02-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-191-30/+1
| | | | * bsp.am: Remove everything but CPPASCOMPILE.
* 2004-02-15 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-151-0/+7
| | | | * bsp.am: Add CPPASCOMPILE.
* 2004-02-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-141-0/+1
| | | | * bsp.am: DISTCLEANFILES = include/bspopts.h.
* 2003-12-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-171-2/+2
| | | | * bsp.am: Use $(mkdir_p) instead of $(mkinstalldirs).
* 2003-12-13 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-131-5/+5
| | | | * bsp.am: s,${PROJECT_RELEASE}/lib,$(PROJECT_LIB),g.
* 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-121-8/+8
| | | | | | | | * Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES. * bsp.am: Replace bsplibdir by project_libdir. Use mkdir_p instead of mkinstalldirs. Remove dirs from PRE/TMPINSTALL_FILES.
* 2003-12-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-111-2/+0
| | | | * bsp.am: Remove project_libdir.
* 2003-12-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-111-0/+2
| | | | | * Makefile.am: Misc. fixes. * bsp.am: Add project_libdir.
* 2003-12-03 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-031-9/+11
| | | | | | | * Makefile.am: Merge-in shared/Makefile.am, shmdr/Makefile.am. * shared/Makefile.am: Remove. * shmdir/Makefile.am: Remove. * bsp.am: Add preinstallation dirstamp support.
* 2003-09-29 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-09-291-3/+17
| | | | * bsp.am: Reworked.
* 2002-07-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-07-191-0/+2
| | | | * bsp.am: Add bsplib_DATA = bsp_specs.
* 2002-02-05 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-061-3/+2
| | | | * bsp.am: Add line break, remove comment.
* 2001-09-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-241-1/+1
| | | | | | | | * Makefile.am: Use SUBDIRS = instead of SUBDIRS += to make automake-1.5 happy. * include/rtems/score/Makefile.am: Use CLEANFILES = to make automake-1.5 happy. * bsp.am: Use PREINSTALL_FILES = to make automake-1.5 happy.
* 2001-02-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-02-021-1/+1
| | | | * bsp.am: Fix automake version number in comment.
* Patch rtems-rc-20000118-6.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-02-021-4/+3
| | | | | | | | | | | | | | | | that contains: The workarounds related to the issues with ppc/helas403 (triggers a nasty bug in automake-2.14) and mcp750.cfg (Which is basically broken) To apply: patch -p1 < rtems-rc-20000118-6.diff ./bootstrap Note: * Though this patch is small, ./bootstrap is absolutely necessary. * Now your CVS source tree is identical to my local CVS.
* Patch rtems-rc-19991203-3.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1999-12-131-0/+14
which adds automake support to libbsp/bare.
