* Makefile.am: Remove reference to non-existing file times.
* console/console.c: Now compiles.
* acinclude.m4: Regenerated for TLL6527M.
* console/console-io.c: Regenerated for TLL6527M.
PR 1781/bsps
* ChangeLog, Makefile.am, README, bsp_specs, configure.ac,
preinstall.am, times, console/console.c, include/bsp.h,
include/cplb.h, include/tm27.h, make/custom/TLL6527M.cfg,
startup/bspstart.c, startup/linkcmds: New files.
Initial port for the TLL6527Mboard that contains blackfin 52X
range of processors. Used eZKit533 as a reference for building
the port.
PR 1781/bsps
* console/console-io.c: The UART RX and TX are different ISR
now. So the array containing the registeration changes. The
change is due to change in the libcup uart function.
* ChangeLog, shared/start/start.S: Add HLT instruction on exit.
* ChangeLog, start/start.S: Add HLT instruction on exit.
* include/tm27.h, startup/bspstart.c:
* startup/bspstart.c:
* Makefile.am: Do not use .rel files for libbsp pieces.
* shared/start/start.S: Pass 0/NULL for argc/argv.
PR 1488/bsps
* start/start.S: Micromon on bf537 uses DMA for UART reception.
This prevents the UART driver in RTEMS from working (and also
causes received characters to be stored in a buffer that RTEMS
doesn't know about, so it's potentially dangerous, but in practice
the risk is small since an RTEMS app intended to be booted from
Micromon would normally be configured to leave the RAM Micromon
uses reserved). The attached patch corrects this by disabling
all DMA channels at startup.
* console/console-io.c: Let bf537Stamp_BSP_poll_char return int.
* console/console-io.c: Let eZKit533_BSP_poll_char return int.
* make/custom/eZKit533.cfg: Remove RTEMS_BSP_FAMILY.
* make/custom/bf537Stamp.cfg: Remove RTEMS_BSP_FAMILY.
* make/custom/eZKit533.cfg: Switch to compiling at O2.
* startup/bspstart.c: Add missing prototype.
* make/custom/eZKit533.cfg: New (relocated from /make/custom).
* make/custom/bf537Stamp.cfg: New (relocated from /make/custom).
* configure.ac: Remove RTEMS_BSP_BOOTCARD_OPTIONS.
* include/bsp.h: Eliminate BSPs defining NUMBER_OF_TERMIOS_PORTS.
Should be automatically handled by confdefs.h or the application.
* configure.ac: Rename BSP_BOOTCARD_OPTIONS to
RTEMS_BSP_BOOTCARD_OPTIONS. Add RTEMS_BSP_CLEANUP_OPTIONS so all BSPs
have the same options.
* start/start.S: Correct call to boot_card to meet bfin abi by
clearing l0 - l3 and allocating some stack space.
PR 1415/bsps
* startup/bspstart.c, startup/linkcmds: Enable caches and therefore
enable the mmu.
* start/start.S: Update for boot_card command line change.
* shared/start/start.S: Update for boot_card command line change.
* bsp_specs: Move -e start from *link to *startfile to avoid warning
for undefined entry symbol when linking relocatables with binutils
2.19.
* Makefile.am: Eliminate bsp.am. Build startup files as side-effect
of building libbspstart.a, using automake-rules.
* Makefile.am: Eliminate *_SOURCES.
* Makefile.am: Move noinst_LIBRARIES = libbsp.a before its
components.
* Makefile.am: Cleanup ../../shared/include/bootcard.h handling.
* include/bsp.h: Rely on clock driver to determine when we should use
fast idle.
* include/bsp.h, startup/bspstart.c:
* shared/start/start.S: Add BFIN_ON_SKYEYE define to disable features
not supported on simulator.
* configure.ac: Add BFIN_ON_SKYEYE define to disable features not
* configure.ac, console/console.c: Add BFIN_ON_SKYEYE define to disable
features not supported on simulator.
* configure.ac, console/console.c: Add skyeye alias for bf537stamp.
