* ChangeLog, shared/start/start.S: Add HLT instruction on exit.
* shared/start/start.S: Pass 0/NULL for argc/argv.
* shared/start/start.S: Update for boot_card command line change.
* shared/start/start.S: Add BFIN_ON_SKYEYE define to disable features
not supported on simulator.
* shared/bspgetworkarea.c: Removed.
* shared/bspgetworkarea.c: New file.
* shared/clock/clockdrv.c, shared/clock/rtc.c, shared/clock/tod.h,
shared/console/console.c, shared/timer/timer.c: Removed.
* shared/clock/clockdrv.c: Eliminate copies of the Configuration Table.
Use the RTEMS provided accessor macros to obtain configuration
fields.
* shared/start/start.S: Initialize bss to zero.
* shared/start/start.S: Fix typo of pO versus p0.
* shared/clock/rtc.c, shared/timer/timer.c: Fix compile errors and
address most warnings about constants being too large.
* shared/start/start.S: Eliminate hi, lo, HI, LO, and MK_BMSK.
* configure.ac, eZKit533/configure.ac, eZKit533/include/bsp.h,
shared/start/start.S: Make use of separated bfin helper .h files.
* bfin/ChangeLog, bfin/Makefile.am, bfin/acinclude.m4,
bfin/configure.ac, bfin/eZKit533/.cvsignore, bfin/eZKit533/ChangeLog,
bfin/eZKit533/Makefile.am, bfin/eZKit533/README,
bfin/eZKit533/bsp_specs, bfin/eZKit533/configure,
bfin/eZKit533/configure.ac, bfin/eZKit533/preinstall.am,
bfin/eZKit533/times, bfin/eZKit533/console/console-io.c,
bfin/eZKit533/include/.cvsignore, bfin/eZKit533/include/bsp.h,
bfin/eZKit533/include/bspopts.h.in, bfin/eZKit533/include/coverhd.h,
bfin/eZKit533/include/tm27.h, bfin/eZKit533/startup/bspstart.c,
bfin/eZKit533/startup/linkcmds, bfin/shared/clock/clockdrv.c,
bfin/shared/clock/rtc.c, bfin/shared/clock/tod.h,
bfin/shared/console/console.c, bfin/shared/start/start.S,
bfin/shared/timer/timer.c: New files.
